AMSOIL at Wholesale for Track Day Forum Members
Old 02-21-2010, 11:00 AM
C66 Racing
Premium Supporting Vendor
C66 Racing's Avatar
Default AMSOIL at Wholesale for Track Day Forum Members
Track Vette Drivers,
If you are interested in trying AMSOIL Synthetic Lubricants for your track or tow vehicles, I'd like to ensure you get your fluids at dealer wholesale, about 25% below retail, via the AMSOIL Preferred Customer Program. Please drop me a PM or email at c66racing@hotmail.com for more info on this program - I'll answer your questions every evening when I get home from my other full time employment.
Track Day/Racing Oils:
AMSOIL makes several grades of Group IV, polyalphaolefin (PAO), synthetic basestock lubricants that meet the various needs of track day or racing Vettes, including track only, dual use (track/street) and with or without oil coolers. All of these contain high levels of ZDDP, or Zinc dialkyl dithio phosphate.
Note: None of these meet GM Standard 4718M
AMSOIL Dominator Synthetic 10w30 Racing Motor Oil
(Product Code RD30QT)
(zinc – 1575 ppm, phosphorus 1474 ppm)
(No detergents)
(This is the oil I use in my SCCA T1 02 Z06)
AMSOIL SAE Synthetic Premium Protection 10w40
(Product Code AMOQT)
(zinc – 1378 ppm, phosphorus 1265 ppm)
(High levels of detergents/dispersants suitable for extended street use)
AMSOIL Dominator Synthetic 15w50 Racing Motor Oil
(Product Code RD50QT)
(No detergents)
AMSOIL SAE Synthetic Premium Protection 20w50
(Product Code AROQT)
(zinc – 1379 ppm, phosphorus 1266 ppm)
They also carry a full line of Group IV, polyalphaolefin (PAO), synthetic basestock transmission and gear lube fluids.
C4 manual transmissions (89 and later): AMSOIL Synthetic Synchromesh Transmission Fluid (MTF) (Product Code MTFQT)
(Pre-89 PM me for info - several fluids available depending on your transmission)
C5/C6 manual transmissions (Dexron III):
AMSOIL Torque-Drive Synthetic Transmission Fluid (Product Code ATD1G)
(This is the fluid I use)
C5/C6 (05s) automatic transmissions (Dexron III)
AMSOIL Universal ATF (Product Code ATFQT)
C6 automatic transmissions (06 and later) (Dexron VI)
AMSOIL Low Viscosity Universal Automatic Transmission Fluid (ATL) (Product Code ATLQT)
C4-C6 Gear Lube:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
Note: The Severe Gear fluid comes with friction modifier already in it and most C4 and C5 differentials do not need extra additive to prevent diff chatter. C6 diff clutch plates behave differently than earlier Vettes and for C6 diffs I recommend one bottle of the Slip Lock Additive.
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
AMSOIL Hand Pump (Product Code G2039)
(Works with any off the transmission or gear lube bottles listed above - I use two, one for gear lube and one for tranny fluid)
Brake/Clutch Fluid
AMSOIL Series 600 DOT 4 Racing Brake Fluid (Product Code BF4SN)
Dry Boiling Point - 580F, Wet Boiling Point - 410F
Note: Owner's Manual Requires DOT 3 Brake Fluid
Power Steering Fluid
AMSOIL Synthetic Power Steering Fluid (Product Code PSFCN)
Info on the multitude of products available for your tow and support vehicles, including CI-4+ diesel oils for pre-07 diesels as well as CJ-4 diesel oils for 07 and later diesels, can be found via this link:
AMSOIL Online Product Application Guide
Orders placed direct with AMSOIL using reference 1206638 will benefit my race team and the forum: AMSOIL Ordering Information
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
Last edited by C66 Racing; 02-21-2010 at 01:44 PM. Reason: Added Brake and Power Steering Fluids
Old 02-21-2010, 11:13 AM
Kubs
Kubs's Avatar
Received 1,719 Likes on 929 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Good deal! When I need oil Ill let you know.
Old 02-21-2010, 06:21 PM
Snuckley
Snuckley's Avatar
Thanks for the post, I keep forgetting to order some more Hydro fluid for my tractor....I use a few Amsoil products regularly in some of the 21 internal combustion engines I maintain. Amsoil was the first to market with synthetic hydro. The hydraulics on my loader come up to full power much quicker in cold weather after switching over from dino. The 100:1 2 stroke oil is cool. I used to have a local dealer that delivered to my farm, but he's out of it now. i'll give you the business. ...... Thanks for serving our country..
Old 03-07-2010, 09:41 AM
C66 Racing
C66 Racing's Avatar
Originally Posted by Snuckley
... i'll give you the business. ...
Thanks for the support, I appreciate it!
Old 03-07-2010, 09:51 AM
Wasserott
Wasserott's Avatar
Brad,
You should still have me as your customer on this program. I've religiously used the the 15w50 racing oil and i'm very impressed!
Thanks,
Chuck
Old 03-10-2010, 10:16 AM
C66 Racing
C66 Racing's Avatar
Originally Posted by Wasserott
Brad,
Thanks,
Chuck
I do Chuck and appreciate the long time support! At some point in the not too distant future, I'm hoping we can meet up at a DE around here sometime.
Brad
Old 03-10-2010, 11:12 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Doing inventory this weekend and then should be ordering what I need Monday.
Bring on the warm months....
Old 03-14-2010, 09:01 PM
geerookie
geerookie's Avatar
Just placed my order.
Old 03-20-2010, 11:38 AM
C66 Racing
C66 Racing's Avatar
All,
I appreciate the support from those that have posted and the many that have PM or emailed me!
Old 04-20-2010, 08:41 PM
C66 Racing
C66 Racing's Avatar
Thanks to all those that have dropped me PMs to order. Appreciate the support.
Old 04-20-2010, 11:21 PM
mgarfias
mgarfias's Avatar
The only beef I have with your list brad, is the hand pumps. The times I've used them to do gear lube they SUCK. Much easier to use a compressor to pressurize the bottle and send the fluid up.
Old 04-21-2010, 10:35 PM
stevensa
stevensa's Avatar
Pm'd
Old 04-22-2010, 01:49 AM
Sidney004
Sidney004's Avatar
I have been using the AFL 5W-40 for the last 110K miles in my Mercedes C280, 10K mile oil change intervals,does not burn a drop between oil changes. Great product and value for any European car that requires a thicker oil per the owners manual.
Old 04-22-2010, 08:18 PM
C66 Racing
C66 Racing's Avatar
Originally Posted by stevensa
Pm'd
Responded, thanks!
Mike - Have you ever tried a hand pump from an auto store? Those really suck. But, you are correct, pressurized bottle would be better. But I'm too busy (lazy?) to figure out how to do that, so I keep two hand pumps, one for diff fluid, one for tranny fluid. Anita can always tell when I've changed my diff fluid do to the wonderful smell.
Old 04-23-2010, 12:43 AM
mgarfias
mgarfias's Avatar
Ugh, I had to throw away a tshirt once because of a hand pump and gear oil. That smell NEVER came out.
To use compressed air, I drill a hole in the lid of one of the oil bottles, and push a length of pvc tubing down to the bottom. Then drill another small hole for the air nozzle. Put the tubing into the diff, then the air nozzle into the hole you drilled, and start pumping air in.
Start out really really low, like 10psi. Too much and you'll wear the gear oil just like with the hand pump. Ok, worse.
Old 04-25-2010, 11:59 AM
C66 Racing
C66 Racing's Avatar
As I read this, I had a picture in my head of how this can go wrong that was probably validated when I got to the end of your post: "ok, worse".
To AMSOIL at Wholesale for Track Day Forum Members
Quick Reply: AMSOIL at Wholesale for Track Day Forum Members
