how much water wetter if planning on non antifreeze?
Old 04-18-2010, 10:52 PM
dvandentop
dvandentop's Avatar
Default how much water wetter if planning on non antifreeze?
how much water wetter should be used if going to a non antifreeze coolant mix?
just installed my dewitts on my z06 and thinking of going to water wetter and distilled only.
thanks
Old 04-19-2010, 07:31 AM
AU N EGL
AU N EGL's Avatar
Two bottles will do
Old 04-19-2010, 08:38 AM
ScaryFast
ScaryFast's Avatar
Originally Posted by AU N EGL
Two bottles will do
That seems to be the concensus. Or you can run 1 bottle plus bottle of the cooling system anti-rust and pump lube from Cyclos or Gunk...about $2.
Old 04-19-2010, 10:29 AM
Aardwolf
Aardwolf's Avatar
I always followed the directions on the bottle and used just one bottle.
http://www.redlineoil.com/product.aspx?pid=74&pcid=10
Use one bottle for most passenger cars and light trucks, treats 3 to 5 gallons or 13.2 to 15.9 liters. Vehicles with larger cooling systems should use two bottles. Small cooling systems should use 1oz (3 to 4 capfuls) per quart
Old 04-19-2010, 10:58 AM
fred_S
fred_S's Avatar
Remember the stuff isn't just for better cooling, it's also for lubricating the water pump.
Old 04-19-2010, 11:30 AM
Liquid1
Liquid1's Avatar
This will prevent corrosion and not be a track hazard if put down on the track? What happens to cooling temperatures versus stock when running this mixture? Thanks for the help.
Old 04-19-2010, 03:48 PM
ScaryFast
ScaryFast's Avatar
It's about the same as WW, slipperyness on track is based more on the fact that you run about 8 oz per 5 gallons versus a 50/50 mix of eth-glycol / water with a "street" antifreeze setup.
Water has a coefficient of dynamic friction (mu) of about 0.5. Water with 3% WW is about the same. 50/50 glycol to water is about 0.35, and straight eth-glycol is 0.2. In other words, if you ran 3% glycol you'd have about the same coefficient of friction as water alone, but get no benefit as far as lubrication and rust inhibition.
It is NASA legal as per the CCR, section 15.17.10:
Ethylene Glycol-based antifreeze and other additives that may cause a slippery condition if spilled on track are prohibited. Other water additives such as Redline WW may be used.
Old 04-19-2010, 04:38 PM
mgarfias
mgarfias's Avatar
Anyone ever run the evans stuff? Er, that is the evans NPG+ coolant.
Old 04-19-2010, 06:59 PM
Cloaked323
Support Corvetteforum!
Cloaked323's Avatar
Many years ago there was an issue with this stuff, something to do with damaging the aluminum radiator IIRC.
Old 04-19-2010, 08:37 PM
Greywolfe
Greywolfe's Avatar
I have a question relating to this. My car is still a daily driver and I also DE it about 5 weekends a year.
If I switch to water and a bottle of water wetter only will I have issues driving it like this every day?
Also doesn't the anti-freeze not only lower the freezing point but also raise the boiling point of the water? Does anyone running straight water have problems with boiling?
I check my hoses during my pre-track check and also periodically during the events but if a hose does ever go I don't want to cause a slick.
Old 04-20-2010, 09:49 AM
ScaryFast
ScaryFast's Avatar
Greywolfe, running straight water (with an anti-corrosive and pump lubricant, of course) is superior in almost every way. The reason to run antifreeze is just that - to keep your water from freezing. As long as you put glycol back in whenever there is a risk of freezing temps you'll be fine.
Water is much better at cooling as it's heat transfer capability is quicker. In other words, it will absorb heat from the motor faster and then release it in the radiator faster than a glycol mix. And of course the issues on track have been covered.
Old 04-20-2010, 09:53 AM
jstout
jstout's Avatar
Chattanooga Area Events Coordinator
Is straight tap water ok with the water wetter, or is distilled required? Jerry
Old 04-20-2010, 11:22 AM
ScaryFast
ScaryFast's Avatar
For an aluminum radiator, distilled is recommended. Just go to a grocery store and buy the big 2 gallon jugs cheap. Make sure you get distilled and not spring water.
I've seen Peak brand distilled water at the auto parts store for as much as a gallon of antifreeze! What a scam.
Old 04-20-2010, 11:54 AM
Aardwolf
Aardwolf's Avatar
Straight tap water can have quite a bit of minerals in it. I don't get fancy with mine and just use filtered water from here at home. Distilled is good too!
Old 04-20-2010, 12:04 PM
TS Motorsport
TS Motorsport's Avatar
How about you guys stop using water wetter and start using better stuff like DEI's radiator relief.
I have this in my z06 and it brought my temps down 30 degrees! I have some if you guys want to try it, PM me for details!
Old 04-20-2010, 12:36 PM
Coldmale
Coldmale's Avatar
I use 2 and no a/f
I have the dewitts and the twin fans
In Middle East at 35deg C, I get 100deg C water and 118deg C oil
Brilliant
Best move i ever made.
In traffic it runs mid 80s/low 90s
John
Old 04-20-2010, 02:42 PM
ScaryFast
ScaryFast's Avatar
What's in it? What's it do? What's it cost?
I'm happy to try it if it meets my requirements. But my car runs cool enough as it sits, so I'd need a compelling reason...as stated in my first three questions.
Old 07-27-2010, 09:44 PM
BADZ
BADZ's Avatar
Where is the best place to buy this? And does it really work?
To how much water wetter if planning on non antifreeze?
Quick Reply: how much water wetter if planning on non antifreeze?
