Tool sizes for brake pad replacement
What are the correct tool sizes for 2010 Z06 brake pad replacement?
Caliper bolts (6 point ?? mm)
Brake Pad Pins (Torx ??)
Do I need some type piston compressor tool? Have never seen one for 6 pistons!
I am replacing 1 piece pads from Carbotech, so I need to remove the calipers.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
21mm socket. Pull the caliper off of the upright and do NOT remove the pins from the caliper.
Remember red locktite on the bolts when they go back in. I believe it is either a 10mm or 11mm wrench for the bleeder screw.
