C4 ABS Issues with Wilwood Calipers
Former Vendor
Plumbing the system into the cockpit is nice but more work. Leaving it under the hood is simpler but won't allow 'on the fly' change. But...once done it's not likely to be changed a lot other than rain conditions either.
None of it is "hard" it just as hard as you want to make it.
It's a cable-actuated proportioning adjustment. Put it inside within reach, and you can adjust it on the fly when doing long sessions.
Former Vendor
Well I showed up for work today and Doug's 1994 chevy truck was in the shop for emergency repairs. The same problem that Daniel is having. We are under the impression that the wheel speed sensors are bad.
Randy
Randy
Thanks for all the replies guys; I will let you know what I discover. I know this set up works I have seen it on several C4 ZR1's and the owners love the results. I just have something off somewhere with this set up/car now I just have to find it (probably something incredibly simple or easy… I hope).
Randy,
I will start tracing everything back and see where that gets me, I still have another set of ABS sensors I can swap them around and see if that changes things at all. When I changed out the first (original) set it did not change anything. If nothing works I may just remove the ABS but IDK as of now. BTW Get your C5 sorted!!!! LOL you’re going to run out of summer before you know it…
Daniel
Randy,
Daniel
I remember reading about resetting the error codes in the ABS computer. Could try that. Also test the lateral accelerometer.
