Z06 Engine removal?
Z06 Engine removal?
Any one remove the C6-Z06 engine from the top? I have a 4 post lift and want to remove a Z06 engine from the top. If you have or know someone that has please let me know I just need some advance advice. Jim Dillon 772 335 8318 home or PM or Email Thanks!!
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
He's AAAAAAALIVE! Missed you this past weekend at VIR, ole buddy. Saw Tim and company.
JD, why do you need to remove from the top? Need whole engine reworked or just partial? Drivetrain? May be more specifics could help some point you in a good direction. As Jeff said, he has probably removed engines top, bottom and each side. Of course, he has a very capable crew that helps out (sons).
I ran for 3 days with the PCA event and the car ran great. On the first session of the NCM event when I came in the engine was making a squeaking sound from the left bank, it sounded like #3 valve spring, so I didn't run the rest of the event. When I got home and check under both valve covers there does not seem to be anything wrong. However after checking the oil filter, ther is filings in the filter and on both of the drain plugs. So I'm pretty sure that the engine is going to have to come out for a tear down. Will know more tomorrow. I only have a 4 post lift and I would like to pull the engine myself. Therefore it needs to come out the top. Any help would be welcome. JD
Hi JD...sorry about your engine problems. I think it would be easier for you to pull the whole drivetrain out from the bottom. If not, you may have to pull the heads and accessories first so you can get it out of the car.
Tim
Tim
Hey Guys!!!!!!!! I know the way to do it with a 2 post lift! The question is how to get it out the top with a 4 post lift????? Thanks, JD
Jim ya still need to get the torque tube/tranny/diff outta the way one could removed them and pull em outta the way then use a cherry picker to remove the motor from the top
car would be sitting on jackstands on the lift then most likely
You have to loosen the cradle and you can leave the TT in place to take out the top. I do it with jackstands and cherry picker. cajunvette (sic?) has a good writeup with pics on his website
Remove the hood, radiator, etc ... out of the way, disconnect and drain all of the fluids.
Disconnect all of the wirng, hoses, etc ... It helps to have a marker pen and ziplock baggies to mark and label the hardware as you go.
http://www.cajundude.com/engineswap.htm
Great write up thanks Guys. I think that this is what I was looking for. Will let you know if I decide to do it myself? Going to talk to some local shops today. JD
so sad to hear the news...
I had a squeak too in my 454 LS7. turned out to be a failing HS rocker arm(s). Doesn't help you with the drain plug metal parts though unless your Rockers ARE coming apart
For the record I paid about $2K to have the dealer R&R my motor the last 2 times.
If my motor has to come out again....I'm BUYING a 2 post lift ( to go with my 4 post in my third bay) and doing the R&R myself.
You could drop the motor out the bottom toby rolling a dolly underneath and using the engine hoist to hold it up while you remove the cradle.
I've done them both ways on my (4) post.
Sucks to have motor problems.
Jim,
