C6Z06 brakes on a C5, what hoses to use
Can you use the stock C6Z06 brake lines (OEM rubber hoses) when installing the C6Z06 calipers on a C5? I know aftermarket stainless lines fit between C5/C6, how about OEM ones?
Former Vendor
To do the swap you need to use the C5 lines. The car end is different C5 vs C6. But the thread size and pitch is the same from 84-2011 on the caliper.
We just did a conversion in the shop using our C5 line kit
http://dougrippie.com/?p=434
These fit in a small flat rate box for ok shipping to you.
Randy
Randy
Former Vendor
Randy
