I use Global West bushings that require grease fittings. This type of bushing is the only type Ive used on all my cars. Its a metal shell with a plastic sleeve.
Looking at their website it looks like they show a grease fitting. If so where did you place it on the control arm and any issues with it.
Dave
Dave
The upper A arm has the grease fiiting in the bushing facing up for easy access. There is as pic on page 2 of engine where you can see the fitting in the blue anodized part of the bushing.
The bottm A arm gets the fitting the A arm. I drilled and tapped the center top portion, but I reccomend the bottom. I did mine 1997 with many track mikes since then.
