Carbotech Pads vs. cheap pads
Old 10-10-2010, 11:02 PM
C4Scoreand7YearsAgo
C4Scoreand7YearsAgo's Avatar
Default Carbotech Pads vs. cheap pads
I did a track event a few weeks ago and it had incredible stopping power.
Old 10-11-2010, 12:09 AM
gkmccready
gkmccready's Avatar
Did you change rotors when you changed pads? Some pads really hate touching rotors that other pads have been on...
Old 10-11-2010, 12:36 AM
C4Scoreand7YearsAgo
Nope, same old rotors. New rotors are next on the list.
Old 10-11-2010, 07:18 AM
AU N EGL
AU N EGL's Avatar
Originally Posted by C4Scoreand7YearsAgo
I literally have to stand on it just to get it to stop now. Is this normal? Are Carbotechs that much better, even for just cruising around town?
YES. Carbotech race pads could be used for normal driving.
Old 10-11-2010, 08:27 AM
sothpaw2
sothpaw2's Avatar
Carbos are that much better even for cruising/daily driving. There are some really crappy street pads out there--never cheap out on brakes.
Old 10-11-2010, 08:30 AM
The Panther
The Panther's Avatar
So Honest Abe when you bought this car it came with Carbotech pads on it?
Old 10-11-2010, 09:07 AM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
On my 92 I just leave the carbotech pads on it.
I ran the same 10/8 combo for street/track duty. With the big C4 brakes (j55) they lasted about 7 two day events and about 3k street miles. Right now I'm on 12/10 and since I'm running time trials (3 - 4 laps and done, 3 - 4 times per day) They have lasted me the entire season (12+ events).
I'll be prepping the car the next couple weekends for my final three events and will see if I have enough pad left for them.
There are two reasons those auto store pads are not working:
The pad material is not compatible with the layer of carbotech material on the rotors.
The pad material is not that good, I had a second set of rotors and would change pads and rotors for the drive home. HATED it, gave up and just left the track pads on.
Old 10-11-2010, 09:54 AM
Aardwolf
Aardwolf's Avatar
Sounds like really low torque pad material, that junk shouldn't be sold.
Old 10-11-2010, 12:26 PM
C4Scoreand7YearsAgo
Haha. That's what I told my wife.
Old 10-11-2010, 06:26 PM
UstaB-GS549
UstaB-GS549's Avatar
I flip back and forth between DT70 or XP12 & my OEM street pads on the same rotors. I don't notice a big drop in brake performance on the street, but then again I don't use them that hard. The OEM pads are definitely not track worthy.
Old 10-14-2010, 10:30 AM
67Ranger
67Ranger's Avatar
if the pad materials arent compatiable, carbotech makes street pads too
Old 10-14-2010, 04:02 PM
Datawiz
Support Corvetteforum!
Datawiz's Avatar
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Just make sure you have a set of headphones on to drown out the squeal.
I hate driving my Z on the road. It's so fugging noisy.
Solution: My second C6 should be here in the next week or two.
Old 10-16-2010, 01:03 AM
C4Scoreand7YearsAgo
Now that I've been driving with these cheap pads for about a week, they don't seem as bad as I initially thought. Don't get me wrong, with these maxi pads on, she still stops like a drunk horse in the mud, but I think the initial shock going from Carbotech's to discount store pads just caught me by surprise. Really makes me appreciate a good set of pads as I was previously convinced that $400 worth of brake pads was a just a well played marketing scheme.
Old 10-16-2010, 09:57 AM
avizandum
avizandum's Avatar
I DD 10s/8s. The comment about pad compatibility is probably your issue. I'd leave the CTs on - DD use isn't that demanding and you'll never have a properly bedded setup switching back and forth.
If it were me, I'd turn the rotors to start fresh...
To Carbotech Pads vs. cheap pads
Quick Reply: Carbotech Pads vs. cheap pads
