Purchased Used: T1 Sway Bars for C5Z looking for P/N for bushings
Gents:
I just purchased a used set of T1 sway bars for my 04 C5Z.
Does anyone know If or what are the individual GM part numbers for the bushings themselves?
Apparently the bars only have 1K miles on them, but I am thinking if you can purchase the GM bushings separately for the sway bars, I might as well chuck them in at the same time and start fresh.
I just hit up VBandP to see if their 38mm & 27mm poly-sway bar bushings will work with these bars, not sure. But I am going with poly bushings from them on the control arms at the same time.
I believe the T1 bars measure (Front / Rear in mm):
38.4mm / 27.5 mm.
Any help would be appreciated!
Andy
38.4mm / 27.5 mm.
Andy
If you call VBP (www.vbandp.com) they can make you bushings to fit. Otherwise check http://www.gmpartsdirect.com/perform...ATID=1392.html and you want the "isolators"... www.gmpartshouse.com (Gene Culley) would probably be the easiest/cheapest place to order them. I'd personally just call VBP, though, they've poured a bunch of different bushings for me...
Front: C-5 38mm Front Swaybar Bushing
http://www.vbandp.com/C5-Corvettes/S...r-1997-05.html
Rear: C-5 27mm Front Swaybar Bushing
Thanks VB and P!!!!
Andy
