Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > General Corvette Topics > Autocrossing & Roadracing
Reload this Page >
What clutch for about 500rwhp and doing some RoadRacing/HPDE
Old 10-23-2010, 07:20 PM
rustyguns
CF Senior Member
rustyguns's Avatar
Liked 5 Times in 5 Posts
Originally Posted by trapp View Post
I have run 2 years on the stock clutch with 500rwhp. I have done alot of track ( road course ) time. I have about 9k on the car without any issues.
te:
Originally Posted by mcar00 View Post
I don't believe that road racing/HPDE puts a whole lot of stress on a clutch. I've run for 3 years (40 track hours) with 500+ RWHP with the stock clutch and never had an issue. They are inexpensive and work well on the street also. I think it's the launching and speed shifting at a dragstrip that really abuses a clutch.
you two guys need to run harder, longer and hotter in the Arizona heat
but you are right the stock clutch should last around 30,000 miles of HPDE's and hiway cruisin' with a stock motor
the stock clutch is a very good deal for the money, its just the install that kills you!
rustyguns is offline
Old 10-23-2010, 10:33 PM
argonaut
CF Senior Member
argonaut's Avatar
Liked 21 Times in 16 Posts
Originally Posted by LeMans05C6 View Post
I thought i would go with at least a solid face instead of puck design.
If you are doing any street driving get a full face design, I personally hate my Monster Stage 3 on the street, it grabs like a ****, really sucks in a traffic jam. Works well on the track though.
argonaut is offline
Old 10-24-2010, 01:31 PM
LeMans05C6
CF Senior Member
Liked 0 Times in 0 Posts
Looking like SPEC Stage2+, just gotta decide on the flywheel.
LeMans05C6 is offline
Old 10-24-2010, 07:20 PM
throwit
CF Senior Member
throwit's Avatar
Speaking from my own experience with the 2+, I doubt very very much it will hold 500whp in "real" track conditions...mine did not, and I am not even at 500 (wish I was ).
Don't gamble, get yourself the 3 or 3+
If you are willing to give up easy launches, and possibly some longevity, for greatly improved performance, get a multi disc.
throwit is offline
Old 10-24-2010, 07:52 PM
LeMans05C6
CF Senior Member
Monster seems to be the 6 puck disc style. From previous comments the full face would help with the daily driver aspect of things. I am lucky right now and get to avoid most traffic but don't want to hate it if i do get stuck in some (DFW still has some traffic at the wrong hour)
The SPEC stage 3+ has the full surfaced disc and even more capacity (claimed at least) than the monster. If i hit 500rwhp ill be happy but that would probably be the max and torque will be a bit lower so I won't be killing this thing, but to have it hold on the high end and take the RoadRace wear I want to do it right. The little things keep adding up but ill have a beast car when I am done.
What is this option by the way? Concentric Hydraulic Release Bearing/Slave Assembly What is this, is it just SPECs slave style or what?????
Can anyone who has used both clutches comment how SPEC and Monster compare. Just like anything else a new car is going to have a different feel and take some getting used to.
Old 10-25-2010, 10:19 AM
LeMans05C6
CF Senior Member
You guys think i really need the Stage 3?
or is it more the road racing that the Stage 3 will be a better long term investment for me?
Just trying to understand becuase it doens't look like ill hit the SPEC stage 2+ tq much less stage 3?
Old 10-25-2010, 05:21 PM
dvandentop
CF Senior Member
dvandentop's Avatar
Liked 39 Times in 34 Posts
stocker here with alot of road course use over 3 years and no issues
36k on car
dvandentop is offline
Old 10-26-2010, 01:08 AM
LeMans05C6
CF Senior Member
I am thinking the Stage2+ would be a fair balance. I just think the stage 3+ is overkill if the stage2+ hold 715lbtq. Even at the fly i won't be close to 600 hp or tq.
Road Racing isn't like the instant grab thats needed in drag racing. smoother on everything on the racetrack is better.
I think ill try this one and see how it does. The monster 3 with the pucks just seems like its gonna be too much for me right now.
The LS7 would probably be fine, but id at least rather be over the power than around the same power it holds.
dvandentop, what power are you running through your stock clutch?
Old 10-26-2010, 09:33 AM
0Mike [email protected] Performance
Former Vendor
Liked 1 Time in 1 Post
Hi, from our experience with all types of clutches that we install every year...the spec clutches have gone way down in quality, especially over the last 2 years...We have had over a 50% faliure & dislike rate...
Here are a few of our special deals we have right now, call me anytime and I will be glad to help you in anyway I can...thanks
To all C6 Corvette owners, this special package price is $1399 + freight, thanks to 37 C6 owners,so far, you guys have made this a very successful special..!!!
Eastcoast Performance is now offering our New *LS9zr6* ZR1 twin disc clutch assembly & flywheel for all C6 & Z06 Corvettes..The LS9zr6 gives you exceptional holding power without sacrificing smooth & comfortable pedal operation. This system does not exhibit any rattle at idle or chatter during engagement and has been tested at over 700 horsepower...
Eastcoast Performance's LS9zr6 Clutch package is on a special purchase price of...$1399 ...
ECPC's LS9zr6 Clutch Package will ONLY work in C6 & Z06 Corvettes!!!
LS9zr6 Clutch Package List of Items...
Included in this system:
_GM ZR1 Twin Disc Pressure Plate Assembly, Clutch Discs
_Steel Billet-(Balanced)-Lightweight Flywheel * made in the USA* (6 bolt flange design for standard LS series engines)
**We include the Flywheel Balance Sheet**
_GM ZR1 Slave Cylinder w/Throw-out Bearing
_GM Z06 HD Pilot Bearing
_GM Flywheel Bolts
_GM Pressure Plate Bolts
_GM DOT4 Clutch Fluid
_ECPC specific C6 (one-man) Remote Clutch Speed Bleeder Kit
_Gaskets if needed
***Hugh Benefits***
Drives like a stock ZR1 - stock pedal feel
Balanced Flywheel
Proven to over 700hp
No neutral noise or chattering
All of the benefits of a twin disk clutch and none of the trade-offs
Group Special Price of $1399
We tried to make sure that we include every little item for the most complete ZR1 style change-over clutch package!!
Call to order yours today!!!
Eastcoast Performance also sells RPS & Monster Clutches, along with All factory Corvette Clutches & Accessories, just call for your special pricing!!!
We accept Visa, MC, Disc, Paypal & Cashiers Checks!!!
2nd Ad...
Hey guys, we just received our shipment of Brand New LS7 Clutch Kits, they are instock ready to ship the same day you order...We also have all the accessories to complete your clutch install...
LS7 Clutch Kit ....$425
Includeds Flywheel, Disc, Pressure Plate & Alignment Tool...
C5 Remote Clutch (One Man) Speed-Bleeder Kit $59.99 w/Clutch Purchase
C6 Remote Clutch (One Man) Speed-Bleeder Kit $69.99 w/Clutch Purchase
ARP Flywheel & Pressure Plate Bolts Both $49.99 w/Clutch Purchase
TORQUE TUBE ACCESSORIES...
Torque Tube Bearing Kit (3 Bearings) $199.99
10mm & 12mm CNC'd Billet Aluminum Torque Tube Couplers, The units we make are Truely BALANCED...!!!
ECPC Billet Aluminum Balanced 10mm Couplers $139.99 each
ECPC Billet Aluminum Balanced 12mm Couplers $145.99 each
(the good ones, these say Made In GERMANY)German 10mm Rubber Couplers $79.99
(the good ones, these say Made In GERMANY)German 12mm Rubber Couplers $79.99
C5 Accessories....
C5 Z06 Clutch Master Unit $79.99
C5 Z06 Clutch Slave Unit $99.99
C5 Z06 Throw-Out Bearing (the good one) $39.99
LS1 & LS6 HD Pilot Bearing $12.99
C6 Accessories...
GM C6 Z06 Clutch Master Unit $129.99
GM C6 Z06 Clutch Slave Unit w/throw-out Bearing $189.99
LS2,3,7 HD Pilot Bearings $18.99
CARBON FIBER DRIVE SHAFTS on Special $899.99
We accept Visa, MasterCard, Disc, Amex, Paypal and Cashier Checks!!!
Mike Yeager@Eastcoast Performance is offline
Old 10-26-2010, 09:44 AM
sperkins
CF Senior Member
sperkins's Avatar
Liked 38 Times in 32 Posts
The Spec 3 was the worst decision I've made yet building my car.
I consider myself a pretty good clutch operator, but I swear no matter what I do it feels like the car is being ripped apart by that damn clutch when starting from a stop. I absolutely hate it. I guarantee it's not good for the TT bushings.
sperkins is offline
Old 10-26-2010, 09:53 AM
drivinhard
CF Senior Member
Support Corvetteforum!
drivinhard's Avatar
Liked 8 Times in 7 Posts
jason's mantra:
light
smooth
cheap
pick 2
drivinhard is offline
Old 10-26-2010, 10:03 AM
LeMans05C6
CF Senior Member
I think if i get close to 500rwhp or just over it I heard the LS7 is coming to the top end of its holding ability there. I'd rather be sure its holding strong.
Regarding the ZR1, that looks like a great deal and tempted, but I am trying to not spend THAT much more money, I am already a bit above the line in the sand as they say so under $1000 would really help.
What do you know about monster clutches?
Old 10-26-2010, 10:04 AM
  #33
LeMans05C6
CF Senior Member
Originally Posted by drivinhard View Post
jason's mantra:
pick 2
What do you mean, sorry if I am a bit slow.
Old 10-26-2010, 10:53 AM
  #34
drivinhard
CF Senior Member
drivinhard's Avatar
you will pick between
light and cheap (but not smooth)
light and smooth (but not cheap, ie carbon discs)
cheap and smooth (but not light)
pick your poison.
Old 10-26-2010, 11:24 AM
  #35
Former Vendor
If you're not going to the drag strip alot the LS7 is the Best all around choice you can make...The LS7 kit will hold more than 500rwhp, the torque is what you have to be careful with when it comes to clutches... Out of them all, the LS7 will drive the best...What year and model is your corvette..?? How much hp/tq do you have right now..?? What are your plans for future Mods..??
pick your poison.
I have never heard it put this way, but its the truth..!!
Old 10-26-2010, 02:44 PM
  #36
sperkins
CF Senior Member
sperkins's Avatar
light
smooth
cheap
pick 2
Heck I didn't get any one of those three with my Spec.
sperkins is offline
Old 10-26-2010, 02:51 PM
  #37
throwit
CF Senior Member
throwit's Avatar
Hey Scott,
Did you get a "newer" clutch from them (within last 3 yrs?)...that may be the degradation of quality I have heard of...the Spec 3 I have is awesome...couldnt be happier. The disc is new, but the PP and FW are the older version, which may explain why...
throwit is offline
Old 10-26-2010, 03:04 PM
  #38
throwit
CF Senior Member
throwit's Avatar
The LS7 is a great clutch considering its price, held my HP/TQ just fine on track, but its heavy as all get out...likely the heaviest of any clutch period. For the street its cool, but I would NEVER recommend that to anyone who actually wants to be competitive in TT or RR.
throwit is offline
Old 10-26-2010, 03:23 PM
  #39
sperkins
CF Senior Member
sperkins's Avatar
Originally Posted by throwit View Post
Hey Scott,
Bought it in Oct '09.
sperkins is offline
Old 10-26-2010, 03:51 PM
  #40
LeMans05C6
CF Senior Member
Right now i only had about 373/369 hp/tq that was with headers only.
The problem is i am doing a 403ci stroker with LS2 stage 2 Heads and i think i may go with a 234/238 .600 114 cam. All of that together is going to change the car dramtically.
I may not hit 500hp/tq but i may be getting closer up there to that number in both hp/tq so that was my worry about the LS7 not holding. I hear its the heaviest but smoothest.
I have been leaning towards the Monster Stage 3. Haven't seen anyone with a bad review yet, but SPEC had mixed reviews some just fine others didn't like it at all.
I doubt to hold the power and not spend a ton it won't be the same old corvette but with a cam and headers and all of this, I really am not tooo worried, just want a reliable decent clutch.
Quick Reply: What clutch for about 500rwhp and doing some RoadRacing/HPDE
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
