What clutch for about 500rwhp and doing some RoadRacing/HPDE
#41
CF Senior Member
#42
CF Senior Member
Originally Posted by Mike [email protected] Performance
Hi, from our experience with all types of clutches that we install every year...the spec clutches have gone way down in quality, especially over the last 2 years...We have had over a 50% faliure & dislike rate...
Here are a few of our special deals we have right now, call me anytime and I will be glad to help you in anyway I can...thanks
To all C6 Corvette owners, this special package price ends on 10/24/2010...Starting next Monday 10/25/2010, Free Freight will no longer be included...thanks to 27 C6 owners,so far, you guys have made this a very successful special..!!!
Eastcoast Performance is now offering our New *LS9zr6* ZR1 twin disc clutch assembly & flywheel for all C6 & Z06 Corvettes..The LS9zr6 gives you exceptional holding power without sacrificing smooth & comfortable pedal operation. This system does not exhibit any rattle at idle or chatter during engagement and has been tested at over 700 horsepower...
Eastcoast Performance's LS9zr6 Clutch package is on a group purchase-special price of...$1399 FREE Freight until 10/24/2010...
ECPC's LS9zr6 Clutch Package will ONLY work in C6 & Z06 Corvettes!!!
LS9zr6 Clutch Package List of Items...
Included in this system:
_GM ZR1 Twin Disc Pressure Plate Assembly, Clutch Discs
_Steel Billet-(Balanced)-Lightweight Flywheel * made in the USA* (6 bolt flange design for standard LS series engines)
**We include the Flywheel Balance Sheet**
_GM ZR1 Slave Cylinder w/Throw-out Bearing
_GM Z06 HD Pilot Bearing
_GM Flywheel Bolts
_GM Pressure Plate Bolts
_GM DOT4 Clutch Fluid
_ECPC specific C6 (one-man) Remote Clutch Speed Bleeder Kit
_Gaskets if needed
***Hugh Benefits***
Drives like a stock ZR1 - stock pedal feel
Balanced Flywheel
Proven to over 700hp
No neutral noise or chattering
All of the benefits of a twin disk clutch and none of the trade-offs
Group purchase-Special Price of $1399 FREE Freight through 10/24/2010
We tried to make sure that we include every little item for the most complete ZR1 style change-over clutch package!!
Call to order yours today!!!
Eastcoast Performance also sells RPS & Monster Clutches, along with All factory Corvette Clutches & Accessories, just call for your special pricing!!!
We accept Visa, MC, Disc, Paypal & Cashiers Checks!!!
2nd Ad...
Hey guys, we just received our shipment of Brand New LS7 Clutch Kits, they are instock ready to ship the same day you order...We also have all the accessories to complete your clutch install...
LS7 Clutch Kit ....$425
Includeds Flywheel, Disc, Pressure Plate & Alignment Tool...
C5 Remote Clutch (One Man) Speed-Bleeder Kit $59.99 w/Clutch Purchase
C6 Remote Clutch (One Man) Speed-Bleeder Kit $69.99 w/Clutch Purchase
ARP Flywheel & Pressure Plate Bolts Both $49.99 w/Clutch Purchase
TORQUE TUBE ACCESSORIES...
Torque Tube Bearing Kit (3 Bearings) $199.99
10mm & 12mm CNC'd Billet Aluminum Torque Tube Couplers, The units we make are Truely BALANCED...!!!
ECPC Billet Aluminum Balanced 10mm Couplers $139.99 each
ECPC Billet Aluminum Balanced 12mm Couplers $145.99 each
(the good ones, these say Made In GERMANY)German 10mm Rubber Couplers $79.99
(the good ones, these say Made In GERMANY)German 12mm Rubber Couplers $79.99
C5 Accessories....
C5 Z06 Clutch Master Unit $79.99
C5 Z06 Clutch Slave Unit $99.99
C5 Z06 Throw-Out Bearing (the good one) $39.99
LS1 & LS6 HD Pilot Bearing $12.99
C6 Accessories...
GM C6 Z06 Clutch Master Unit $129.99
GM C6 Z06 Clutch Slave Unit w/throw-out Bearing $189.99
LS2,3,7 HD Pilot Bearings $18.99
CARBON FIBER DRIVE SHAFTS on Special $899.99
We accept Visa, MasterCard, Disc, Amex, Paypal and Cashier Checks!!!
_GM Flywheel Bolts
_Gaskets if needed
***Hugh Benefits***
Balanced Flywheel
2nd Ad...
C5 Accessories....
C6 Accessories...
#43
Former Vendor
#44
CF Senior Member
Thanked 0 Times
in
Okay if i am now considering the LS9, what other twin disk clutches for under $1500 offer good driveability. I think they all will easily hold the power I am looking to put down, if i am going to step it up to twin disk....
WHATS THE BEST FOR $1500 and below, besides the LS9 which is a very good clutch i have gathered.
#45
Former Vendor
#46
CF Senior Member
Thanked 0 Times
in
Worked with Mike and have the full LS9 clutch on the way. Only rave reviews about this thing and will have no problem holding my power and serve my dual purposes well. Thanks Mike for the help and ill review it once i get my car back probably in a month.
#47
CF Senior Member
As a note I have the spec stage 3 if anyone needs one I just drive my car on the steet mostly so its up for sale. Just PM if interested make offer also have a the stock LS7 clutch for sale both in excellant condition 900 miles on each.
#48
CF Senior Member
Thanked 0 Times
in
Don't have the car back yet and will still be a few weeks out i bet. Whole engine build takes more time than expected to do it right but its working.
#49
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Thanked 406 Times
in
St. Jude Donor '08
For road racing there is no btter clutch then the LS9x. The 8.5 pound reduction in rotating mass makes the car rev quicker and also de-celerate quicker. It is a win-win for all applications.
I highly recommend the aluminum version because of that reduction in weight. Many of the other versions of the LS9 use a heavy steel flywheel and in some instances, it actually weighs more then the stock setup. The other advantage not available in other versions is the ability of replacing the steel insert on the flywheel for $59. The replacement pressure plate is also available for less then $500 when it wears out.
I offer the Katech LS9x shipped to your door for $1,425. That includes everything (Katech alum flywheel, ZR1 pressure plate/discs, ZR1 slave and throw out bearing, all pressure plate and flywheel bolts, pilot bearing, exhaust gaskets, bottle of Dot 4 fluid)
RICH
#50
CF Senior Member
Thanked 0 Times
in
Probably got a similar thing from Mike Yeager. The clutch should be a solid choice for what i hear ill have just over 500rwhp.
Went all out on the build for my LS2. Got the FAST102, NW102 and a new Halltech intake to match.
Many things have shipped and i think the shortblock is close to shipping out early next week. Can't wait.
#51
CF Senior Member
does that zr1 twin disk clutch just bolt in to the c6z06? I was told to get a new throw out bearing with this setup, yes or no? is the alum flywheel readily available for this zr1 clutch. I primarily do HPDE advanced grp. road courses 2x/month w/ 500rwhp z. thanks guys
#52
CF Senior Member
I run a Textrailia Z grip and love it. has 20k+ miles on it and holds like a dream. i can putz around town or click off 1.5 60s at the strip. its good all around
#53
CF Senior Member
Another option that we have just released is an 11" Carbon/Organic it will easily hold 525rwhp and with it's full face disc will have a smoother engagement than a 6-puck disc. This clutch coupled with our lightweight billet flywheel would be great for road racing as it weighs just 42lbs and would make rev matching when heel/toe downshifting easier. Give me a call at 817-750-2000 if you have any questions, Chris
#54
CF Senior Member
Found this thread through a search.
I'm wondering if the ls7 or ls9 clutch with lw flywheel is still considered the best set up for a c5z that does hpde often. I'm stock power wise, but do not see myself going more than cam,headers,exhaust, and heads in the future.
If there's a better clutch setup, please advise.
#55
CF Senior Member
I'm probably the only one who will say this, but I have had great luck with the LS7 clutch. It is reasonably priced and performs well. (480 whp) I also use a Findanza lightweight flywheel.
I wouldn't use it for drag racing, but for road racing I find that it satisfies my needs. On the other hand, I do my best not to abuse it or my tranny.
Your results may vary...
Jim
#57
Supporting Vendor
http://monsterclutches.com/c5-corvet...reet-c5-clutch
#58
The Monster LT1-S Street twin is the best setup. Far more robust, lower MOI, and holds a lot more power, and abuse.
I went with the light flywheel which exposed an existing idle issue in the tune but a fellow forum member did a few tweaks which fixed that. My car is an LS3 conversion (in C5) with mild cam and long tube headers.
The old clutch was an LS7 which was having the stuck pedal any time I tried to do a shift at RPM's above 5000. That clutch is cheap but very heavy.
#59
CF Senior Member
Monster LT-1S - Just make sure you balance it. Petal is as light or lighter than stock and engages just like stock. LOVE this clutch.
Oh yea, and its smaller and lighter so has a much better MOI
#60
CF Senior Member
For HPDE and road course work go with the lightest stock clutch you can and have it balanced. You start getting into unsprung, hard grabbing clutches and you'll be buying tranny parts.
These guys are all trying to sell you something you don't need...but that's their job
The Following User Says Thank You to fmcokc For This Useful Post:
DK83 (04-27-2017)
