front wheelhouse replacement?
I am replacing both my front wheel houses on my c5. They don't exactly line up as good as the originals and I want to get the panels perfect, as they were before. I've left the driver's side on as a reference (will replace after pass. side is done)so I could bolt the front bumper on as well as the right front fender/wheel house. Only having to adjust one side at a time. It's close, but not perfect and having only one set of hands it seems as though it will be a challenge to get it right. Anyone done this before?
Most likely I'll just get it close and then have the body shop finalize the fitment and glue them in, but before I go there I thought I'd ask first. Initially I was actually thinking of sinking some threaded inserts in the frame rail and a-pillar so I could screw the wheelhouses on, which will allow for adjustment, but for a street car with all the other crap in there, etc., I think the glue is the way to go. If only gm made these in multiple pieces I wouldn't be doing this. The very front lowers that attach to the bottom of the bumper cover broke off and here I am.
thanks in advance,
-V
thanks in advance,
-V
thanks in advance,
-V
thanks in advance,
-V
Is this a street car or a race car?
When replacing the front wheelhouses on the front of a C5 Corvette, you will need to do test fits using the the front nose hood and fenders to assure proper alignment before doing the final glue in.
Been there and done it. An experience body shop experienced with Corvettes is best to do the fitment.
