Let me ask another way, who's LS3 HASN"T blown up on the track
#81
yes this post has certainly gotten interesting.
As the OP I can add this. I am putting R888's on my stock LS3, running as many HPDE's as I can this year and hoping for the best.
I will report on engine status at the end of October, wish me luck :->
#83
I believe we've beat that horse to death though. ha ha
#84
Of course that could be because of my busted foot, but whatever...
#85
I'll be doing the same
#86
All - My apologies for interjecting comments (i.e., my earlier posts on my Accusump issues) that seem to have hijacked the OP's topic on LS3 reliability.
- Electric Valve. I have one in my setup, but I don't think that's had an impact on preventing the relief valve 'puking' issues I've had. More important are a fully mission capable (FMC) internal components of the sump (i.e., o-rings, bladder), a FMC sump gauge with no internal leaks (so that the bladder doesn't leak pressure and bottoms out in the sump can), and a modified relief valve setup that either includes a catch can to collect the oil that pukes out as the relief valve is designed to do when internal sump pressures get too high or reroutes puked oil back to one of the valve covers.
- Sump volume. Go 3 qts.
- Sump install location. I only have my C5, but summise that there are install kits that also allow C6 owners to have the sump mounted on the frame, just fwd of the driver, inside the LF fender. Is it modding? In a way, yes, but a well-designed install kit will keep further modifcations to a minimum. The fender should bolt back on with no body panel modding needed.
Final thought. Not to say that a wet sump system (e.g., the Canton Accusump) is not worth installing. Its addition will help protect your investment when on a road course. However, as Chris ("wtknght1") has alluded, and if your wallet allows, go with a dry sump system if you can.
PM me if you want any other thoughts I have on the Accusump or my experiences with the system.
Presuming the system does eject oil again from the safety valve, which is then routed back into the engine, how is it that the (again, presumed) hydrolock is resolved? It seems that, in comparison to earlier such events where you manually fixed the issue, the reoccurence now will leave you without notice of a non-functioning Accusump which could be a subsequently fatal issue. If the issue is distortion of the housing due to temperature differential across the surface, then the mentioned FMC components will not address this. Not quite the same as the shuttle but working towards it, invoking Feynman.
Blizzard1975 (02-16-2021)
#87
I'm not an expert in engines or in wet sump oil systems. I do not have blind trust, but I do place a level of trust in my mechanic and some trust in the Accusump as a purposely designed product that will help protect my engine investment while on the track during HPDEs and track days. None-the-less and based on the past, I will have to keep an eye on things.
I'd love to sit down with Canton, the CF sponsor who makes the install kit, GM Corvette engineers and my mechanic to constructively discuss the correct solution or a preventative redesign (as needed), but I don't think that will ever happen.
I'm at the end of my knowledge on my Accusump oil puking issues. I know nothing else on this issue other than the facts associated with the install and use of the system on my 'Vette.
I welcome others who want to comment on any actual or perceived Accusump issues, but as one who feels the original subject (LS3 engines) has been "highjacked" by myself and others, request any further Accusump discussions be diverted to a thread of it's own.
If anyone wants to chat up my mechanic (a CF sponsor) about his solution to my issue or his thoughts about the product and the install kit we used, please PM me and I'll give you his website/link. (No guarantee implied on my part that he'll answer each and every e-mail msg. But, I bet he will give some type of response.)
Thank you. Be safe out there!
#88
Put a trip pressure switch inline to the engine vent from the safety valve. Rig it to a warning light.
Add a schraeder valve next to the safety valve (probably one rated for a fuel injection system will have proper specs). Now you can manually purge oil from the air end of the cylinder after the light has been tripped by applying gentle air pressure (hook up a drain line to the other "charging" schraeder valve on the top of the cylinder). Reset the light. Precharge the cylinder.
Insulate the cylinder.
You're right; I won't know if I still have the same issue. Not unless I have oil seeping out from between my fender and dripping on the ground, of course.
#89
St. Jude Donor '11-'12-'13-'14
Is their an aftermarket dry sump kit available for the LS3? Or are people using the LS7 setup and rigging it to work with the LS3.
Pardon my ignorance, I'm a new vette owner and am looking to race my car on the weekends but need to learn as much as I can before taking that initial plunge.
Thank you
Thank you
#91
Pardon my ignorance, I'm a new vette owner and am looking to race my car on the weekends but need to learn as much as I can before taking that initial plunge.Thank you
The best piece of advice I can give you though is to make sure that the scavenge pump pulley and all those tiny screws are installed tightly and with red lock-tight; and you mark all of them so you can visually inspect to ensure nothing has loosened up. Run the oil level 1" below the screen in the tank and you won't have any excess oil puke over into the catch can.
Put the biggest oil cooler(s) you can find on there, but try not to block too much of the radiator. These engines run hot!!!!!!
Do all this and your oil pressure will be consistent and high regardless of the track or turns.
#92
I may be off-base here, but I had an '08 LS3 with 15k miles before I traded it on a ZR1. Of those 15k miles, literally half of them were track miles at ***** out track days. I had intake, headers, exhaust. Internally stock. Kept the engine at 1 quart over with 5W-30 M1 synthetic.
Zero issues whatesoever even at oil temps upwards of 305F. I guess I was lucky, but the car ran like a bat out of hell and I never had any issues at all except a blown clutch master cylinder at Texas World Speedway. Guess you're supposed to flush the clutch fluid occasionally using Rangers method. I never touched it and the master cylinder went at 13-14k. Engine had been redlined probably a couple thousand times or more in that timeframe.
From my 12 years of track day experience (basically since college), I have seen the track day problems on Corvettes originated 99% from these sources:
1. Not enough oil (manual says 1 quart over on the non-dry sump cars)
2. internal engine modifications
3. bad aftermarket engine tune
I trust GM to know what they are doing on the inside of the engine which is why I've always not done internal engine mods. Also, aftermarket tunes always open the door for bad things to happen. I always make sure I have the appropriate oil level.
Check out "quikagc5" on youtube and you'll see more than a dozen track day videos of my '08 LS3 including some acceleration runs. I had R888 tires and beat the **** out of the car. It loved it. When the oil temp got around 300F, I'd start short shifting around 5500rpm. Otherwise, I'd run it to red line all day long.
I firmly believe a lot of engine problems on the LS3 motors (and other LSx) engines are due to aftermarket parts (including oil coolers, dry sumps, cams, tunes, etc.)
The closer you can keep the car to stock with the quart extra of oil, the more likely your car will be just fine for several years of hard track days.
Just my 2 cents from real-world application with personal experience. I'm sure others have different opinions and experiences.
The following 2 users liked this post by QUIKAG:
72greg (05-18-2022),
BigMonkey73 (11-23-2016)
#93
Great replies guys, thank you very much. This forum is full of useful information.
I just got my car a few weeks ago and am already shopping around for some HPDE locations etc in Florida. The car is my DD so I'll gladly take any necessary extra precautions to minimize the risk. If I need to drop some money into a good dry sump system, then so be it. An ounce of prevention is worth a pound of cure, right?
Thank you again
Thank you again
#94
Not to say those of use with LS6s have NOT had these issues as well. We have.
#95
I'd like to know how many LSx motors grenaded with stock internals, stock tune, and stock non dry sump oiling system with a full quart over. I bet it's not very many. I know there will be some, but it's not going to be a high number. Every single Vette engine grenade I've personally seen and heard about at track days included either not enough oil, aftermarket engine internals, or a crappy aftermarket engine tune.
Here is a vid I got a few weeks back of a Z06 blowing up in front of me. He had just had a tune and aftermarket cam put in a few months prior and this was his first track day with this new combo. Car was running damn strong in this session and I was having a hard time keeping up with him (until it blew up).
Check end of this short clip (sorry for camera angle. It got pushed down by accident):
http://www.youtube.com/watch?v=pLymr8ehcys
#96
So I'd like 450 at the wheels and to get there, I'll need headers, intake and probably heads and a cam (mild). All that will need to be tuned I'm sure. Are you saying that it's likely the motor will grenade with a combo like that? That seems awfully mild as far as mods are concerned and 450whp is barely scratching the surface.
Again, I'm new to this so pardon my ignorance.
#97
Agreed, but with a stock tune and stock internals, going a quart over full seemed to work great for me with dozens of hard track days with my '01 C5 (LS1) and '08 C6 (LS3) all on R-comp tires. When oil temp got near 300F, I'd just start short shifting until it cooled down a little bit.
#98
Now that may not be a problem IF and WHEN you highly maintain your engine. Racing engines are measured in HOURS of use, not miles
Change springs at least once if not twice a year. Check the valve seat pressure at that time as well.
What do mean by "mild cam" ?
an accu-sump or better yet a dry sump will help.
Remember Road racing or HPDEs / Road Track events are far different the drag racing. The guys over on LS1 tech, for the most part dont have a clue what goes on inside our engines.
When you tell the few knowledge ppl on LS1Tech the engine is for road racing, they change their whole idea of what you need for sustained high rpm use for long periods of time.
the old saying goes:
High HP, Reliable and moderate Cost. Pick TWO, as that is all you get.
I also would love a 450 rwhp engine or three. but at $10-$14 grand each its not going to happen.
#99
