Caliper Bracket bolts, do you change them?
When changing rotors often, do you swap out the caliper bracket bolts?
I read they are one time use but I also read that they are re-used with red locktite.
They can be costly.
What are folks doing?
They can be costly.
Just make sure you clean the red stuff that is on them from the factory. I switch mine out once a month so I don't loctite them. Actually I don't even torque them. 125 ft/lbs is a tight as I can get them with my medium breaker bar, so I just tighten them as much as I can and go with it. So far they haven't come off. Same with the caliper bolts. Shop manual says to replace, but for the shop, it is cheaper to repl than to take time to clean red stuff off.
Don't waste your $ replacing those bolts !! They are high tensile strength and will last a lot longer than the bracket they screw into. If you are really ****, you can use a wire brush and clean all the old red material off the bolt and chase the bracket with the correct size tap and then reapply some Blue loktite before retorquing. I just cleaned mine up good once and place a small drop of Blue on bolt at each reassembly. Have not had a problem on the current bolts that have been in and out at least 50 times over the last 7 years.
If you do have to replace the bolts, make sure they are a metric 10.9 strength (same as SAE Grade 8). OEM bolts come with a threadlocker already applied.
