Oil Pressure at High RPMs...should I be concerned? Please advise!
Old 07-26-2011, 09:37 PM
throwit
throwit's Avatar
Default Oil Pressure at High RPMs...should I be concerned? Please advise!
Hey guys,
I am seeing ~45psi at 6500rpm, ~250+ degrees, 15w50 Mobil1. Its a 427 with Ron Davis Radiator w/EOC. It has a the good melling pump in it with red spring. oil and filter are fresh. It idles fine when cold (~55psi) and when hot (~35). Its just the high rpms dont fall into the "10 psi per 1000 rpm" rule of thumb...so I honestly don't know what to think.
What I really need to know is if this is a real concern on track? or not. Is the engine really at risk at 45psi at WOT for extended periods of time?
Please Advise
thx
Old 07-27-2011, 12:44 AM
froggy47
froggy47's Avatar
Old 07-27-2011, 05:22 PM
GOTHAM VETTE
GOTHAM VETTE's Avatar
Jeez, what kind of pressure should you be seeing at redline when your oil's hot and you're on track? I typically only watch the oil temp.
I'm only running 5W30 right now and haven't had any problems, but if I'm curious about whether I should be stepping up to a thicker oil..
Old 07-27-2011, 05:28 PM
95jersey
95jersey's Avatar
45PSI is fine when that hot
Old 07-27-2011, 07:16 PM
TS Motorsport
TS Motorsport's Avatar
You should worry about your oil pressure dropping not rising. It really depends on what type of oil to use but in a basic answer, that's normal.
Old 07-27-2011, 07:51 PM
gkmccready
gkmccready's Avatar
I only worry when my oil pressure drops in to the teens during sustained left hand turns. :-/
Old 07-27-2011, 08:08 PM
morris
morris's Avatar
Do you have a stock oil pan or aftermarket and still seeing that?
Old 07-27-2011, 08:11 PM
throwit
throwit's Avatar
A couple of engine builders have told me that it was a bit low for the given RPM...so not necessarily worried about the pressure rising; more like not rising ...
Old 07-27-2011, 08:12 PM
throwit
throwit's Avatar
slightly modified LS6 to fit the bigger crank
Old 07-27-2011, 08:39 PM
gkmccready
gkmccready's Avatar
Stock LS2 for me. Data logger clearly shows T2 a Thunderhill causes oil pressure to drop below 20psi...
Old 07-27-2011, 09:31 PM
morris
morris's Avatar
Ahh got it I was thinking ls7 dry sump didn't realize we were talking about coupes.
Old 07-28-2011, 11:04 AM
throwit
throwit's Avatar
Its an LS2 427 in a C5Z...
Old 07-28-2011, 11:37 AM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
that's the key
I would listen to DRM/LG/Pfadt, or a solid LS RR engine builder
.......otherwise, it's just speculation
Old 07-28-2011, 12:59 PM
throwit
throwit's Avatar
Originally Posted by SteveDotenMotorsports
that's the key
I hear ya and I agree...
But I do think there is something to gain from asking this forum since many guys track their car and do have the first hand experience of what oil pressure their engines run at.
I do know that 45psi at 6500rpm is not ideal, but what I really need to know is if it is unsafe...
...so far sounds like it is okay.
Old 07-28-2011, 01:18 PM
SteveDoten
SteveDoten's Avatar
very true, I've gained a lot of knowledge from Rx-Ben, he runs TTB/2001 coupe at Glen, Ohio, NJMP, Pocono
always gaining good info with every track weekend
Old 07-28-2011, 02:28 PM
RX-Ben
RX-Ben's Avatar
I would say that 45psi is not super comforting but much better than the 35psi I was seeing at Pocono. The GM min spec at 4krpm is 24psig = 38psi on the gauge.
Oil pressure comes from the bearing clearances (and can be lost via the oil-pickup o-ring!), so that is where to look. If you have looser clearances than stock, you may want to run thicker oil. If you have stock clearances, the thicker oil will likely not be able to get into and fully lubricate the bearing/crank/cam interfaces. The gauge will show higher pressures but lubrication will be compromised. There is an oil thread in this forum, skip to towards the end for thicker/longer-chain oil issues.
If you want some comfort, cut open the oil filter and look for bearing shavings. I don't think you'll find any.
The 10psi per 1000rpms rule is from Smokey Yunick (his autobiography is a great read- Best Damn Garage in Town). I think it is at least a couple decades old and predates modern engine oil. Around 50psi seems to be standard at redline in a variety of engines (I see that when my oil isn't as hot as hades), including 9k rpm NASCAR mills.
Old 07-28-2011, 04:01 PM
throwit
throwit's Avatar
we just replaced the pump (correctly)...so not an o-ring issue. we are already running 15w50, so realistically not gonna get much thicker than that...
i guess everything is okay...the whole 10psi per 1k rpm is really what threw me for a loop...a lot of folks still believe in that rule, but I guess it is a bit dated. No choice but to run her and hope for the best.
she will be at road atl in a week, so we will see what happens
To Oil Pressure at High RPMs...should I be concerned? Please advise!
Old 07-28-2011, 04:13 PM
RX-Ben
RX-Ben's Avatar
Well, there is always 10W-60
http://www.turnermotorsport.com/p-10...m5-e63-m6.aspx
Old 07-28-2011, 06:33 PM
froggy47
froggy47's Avatar
A lot of folks change their street engine oil every 3000 miles, still.
Flame suit on.
Old 07-28-2011, 07:32 PM
throwit
throwit's Avatar
Flame suit on.
Speaking of which, I haven't changed my oil in over 60k miles in my corolla ...just keep adding...
Quick Reply: Oil Pressure at High RPMs...should I be concerned? Please advise!
