Hawk and Wilwood brake pads for Wilwood SL6 calipers
Old 08-02-2011, 12:13 PM
PushinTheLimit
PushinTheLimit's Avatar
Default Hawk and Wilwood brake pads for Wilwood SL6 calipers
I have the LG Wilwood SL6 calipers on the front of my C5Z and the stock C5Z rear calipers. I just wanted to do some research and price check on the Hawk DTC-70's for these calipers but wasn't sure what website I could use. The part number on the rear for Hawk I have is HB248... is that correct? I need the part number for the front on these.
As for the Wilwood's... I know the front part number is 7420 for the SL6 caliper, but what is the part number for the rear that I need? Thanks.
Old 08-02-2011, 12:57 PM
sperkins
sperkins's Avatar
Hawk DTC-70 rear part# HB248U.650
Wilwood front: HB521 shape
HB521-DTC70-.800 would be what you order.
Old 08-02-2011, 01:06 PM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
The SL6 wide body calipers use pad HB521U.800
The narrow SL6 uses HB521U.550
The U is for the DTC-70 compound.
Hope this helps.
Old 08-02-2011, 01:50 PM
PushinTheLimit
Hope this helps.
Thanks for the info... are you sure its HB521U.550 or is it HB521U.650? Everything I've seen so far has been .650 for the DTC-70 compound.
Old 08-02-2011, 06:29 PM
96CollectorSport
Sorry .650 - you are correct I must of hit a 5 on accident. Stupid sausage fingers.
To Hawk and Wilwood brake pads for Wilwood SL6 calipers
Quick Reply: Hawk and Wilwood brake pads for Wilwood SL6 calipers
