Suspension question
Suspension question
I have 15 track days become quite fast leading the intermediate 2 group with a 2007 c6 with cai, tune and headers exactly 385 rwhp and 370 torque. Except for the 911 turbo and cars with 500+ hp outrunning most. I have z51 springs and F55 magnetic shocks and hotckins swaybar. I and thinking I am overdriving the suspension on slicks and scraping the front skid plates and feel the back end bottoming out. I also use the vette on the street. I have a 6 point and racing seats. I find the factory brakes with racing pads fine what is my best suspension move to get to the next level?
We have a couple different options that I think would work well for you.
Our Johnny O'Connell package was designed for daily driver Corvettes who see some occasional track time. Generally that type of driver isn't using R compounds, but is probably running an aggressive street tire. For your daily driving and occasional track day needs the Johnny O'Connell package is working great. You will absolutely see an improvement with the JO shocks and Sway bars, although it's not as aggressive as a coilover style seutp.
If you're a more serious track day user you should look at our new FeatherLight Generations Single Adjustable Coilovers. Not only will you have the ability to tailor your ride heights for more aggressive stance and Center of Gravity improvements, but the adjustable damping rates will allow you to quickly change your ride quality from mild on the street to aggressive for track use with race tires. The spring rates we have selected work well for both street and track use. Newly redesigned FeatherLight Generations Singles will offer our users the flexibility to grow into their suspension packages... If you're mostly daily driving with ideas of a track car on the horizon, the coilovers are robust enough to handle both very successfully.
I do like the Coilover idea but have heard they are difficult to dial in and noise. This is not a daily driver right now 60 percent track 40 percent Sunday cruiser
If you go to coilovers you will have to take care of the electronics of the f55 package and to do it the correct way is not so easy because we tried the sims and they didn't work but we know how to fix the problem.
Can you share the fix?
I was going to buy the plugs from zip to bypass the f55. Any advise would be appreciated.
If you have or know someone who does have access to the GM TechII tool you can disable the F55 suspension pretty easily. Normally it's a situation that conversation with your Service Tech and a 6 pack can solve pretty quickly. Using the TechII is really a more elegant solution than a simulator plug. Although the plugs do work, and should be available from Caspers Electronics.
The Chevy dealer had never done the delete before. But with printed out instructions from the forum they tuned it out no problem. Well, there was one small problem. They took about 12 minutes and charged me the full half hour qoute.
Are these coil overs shipping out this week?
I'd hate to have to plug my module back in to make the track day and pay to remove it again.
Because we are an engineering firm and have access to OEM CAD Data, we have designed our coilover systems for proper fitment on OEM C5 and C6 suspensions. No setup or fiddling required to maintain quiet and reliable operation... just bolt the coilovers up, set your ride heights and go.
Interesting that you had to go through more lengths to disable your ZR1 system. Feedback from our vendors who have done ZR1 installs with our coilovers has just led us to believe it's just a few minutes with the TechII. We will keep an eye on this in the future. What other measures were required for your installation?
