Trans cooler w/o diff cooler?
Old 10-10-2011, 02:35 PM
travisnd
travisnd's Avatar
Default Trans cooler w/o diff cooler?
Got the high trans temp warning for the first time ever racing at VIR this weekend. Got it the first time at the end of the day during the Comp School race on Friday and then after 17 laps (about 35 min hard running) in the hour long fun race on Sunday. Made it through the 20 and 25 min points races on Saturday w/o issue.
For years running a good synthetic ATF (I use Amsoil) and wrapping the exhaust with header wrap has sufficed for HPDE and TT use... but neither are like running all out lap after lap.
Anyone get by with just a trans cooler? Or, do most folks do both? Which one is more important?
I think I remember reading somewhere that by adding a trans cooler only you still cool the diff some since the two units are linked. I.e. cooler trans = less heat transfer to the diff.
Old 10-10-2011, 02:39 PM
AU N EGL
AU N EGL's Avatar
Both are best,
But I only have a trans cooler.
Old 10-10-2011, 02:56 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
So far I only have a trans cooler.
travisnd
travisnd's Avatar
Which one? DRM, T1, homebrew?
Old 10-10-2011, 02:58 PM
C5ZEE06
C5ZEE06's Avatar
i just added a DRM diff cooler (always had the DRM tranny piece)...thinking it could extend the life of the unit (and fill/drain intervals)..and maybe even improve the LS action ...just maybe..but that part could be a stretch.
Old 10-10-2011, 02:59 PM
RX-Ben
RX-Ben's Avatar
I did some research on pumps - this one looks like the best:+
http://www.rbracing-rsr.com/oilsystems.htm (the 2gpm one, $225 per)
Roll your own lines and a bracket for the cooler and you should be all set.
Old 10-10-2011, 03:16 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Parts from the bottom of Mark's SHO parts pile.
Old 10-10-2011, 04:28 PM
redtopz
redtopz's Avatar
I've been running with only a diff cooler for over a year and it did help keep the tranny slightly cooler. I didn't get the tranny overheat warning as often as I used to. However, I'm adding a tranny cooler this week because anytime I race at a track that requires 2nd gear I overheat the tranny. I thought about a diy kit, drm, and T1. I chose DRM.
Old 10-10-2011, 05:31 PM
Scooter70
Scooter70's Avatar
I have the DRM kit with both trans and diff coolers that I'm not going to install. For sale, new in the box. Send me a PM if you're interested.
Old 10-10-2011, 10:55 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
GM engineers told me trans temp is much more of a problem than diff....if you can only do one, definitely do the trans.
Old 10-10-2011, 11:56 PM
CP Thunder
CP Thunder's Avatar
We pulled our diff cooler off to save weight........just change the fluid a little more frequently.........
Old 10-11-2011, 09:10 AM
travisnd
travisnd's Avatar
Thank you sir... I really only want to do the one at this time. Hopefully the Amsoil ATF and the Severe Gear 75w110 gear lube did their jobs protecting everything. Going to drain/refill before RA in December.
Old 10-11-2011, 09:23 AM
BERETTA
BERETTA's Avatar
I went with DRM and did them both at the same time - if you don't already have ear plugs you may want some after the install
Old 10-11-2011, 09:47 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Yeah mine sounds like a garbage disposal. The youtube installation video I watched mentioned that, so I didn't freak out too much, but it's still pretty loud at idle. You don't notice it at speed.
Old 10-11-2011, 09:57 AM
drivinhard
drivinhard's Avatar
ballast comes in many shapes/forms when you have a 250 lb limit
Old 10-11-2011, 10:28 AM
travisnd
travisnd's Avatar
250 lb limit? Sweet... that means I can gain 12 pounds considering I am the ballast
Old 10-11-2011, 10:48 AM
z06801
z06801's Avatar
I was getting the high temp warnings and then the diff went I was bouncing of the rev limiter on every right hander. For the new build I went with this, driven coolers on both
To Trans cooler w/o diff cooler?
Old 10-12-2011, 03:23 PM
yakisoba
yakisoba's Avatar
trans cooler only. Think I just have to change diff oil a bit more often. Trans cooler definitely needed.
Old 10-12-2011, 03:55 PM
C5ZEE06
C5ZEE06's Avatar
Originally Posted by z06801
I was getting the high temp warnings and then the diff went I was bouncing of the rev limiter on ever right hander. For the new build I went with this, driven coolers on both
nice stuff indeed.
Old 10-13-2011, 04:10 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
There is no reason to use an electric pump to do this. To much added weight and power draw on the electrical system. Not only that you have to remember to actually turn it on.
If you do not have a C6 that has one or both of the factory pumps on the cars we have had a mechanical system now for years that you can use (and what we still run on the race cars to this day). We offer then in a two stage setup for trans and diff both, or single stage for either setup. Everything is ran off of the pinion nut so as soon as the car is rolling, fluid is pumping.
Moves a lot of fluid and has almost no power draw on the drivetrain to move it.
I have a number of setups from just cover and pump kits, down to full line kits with filters.
Dual stage shown above
Quick Reply: Trans cooler w/o diff cooler?
