first issue with the c5z
Old 10-15-2011, 10:11 PM
TRACKMAN2
TRACKMAN2's Avatar
Default first issue with the c5z
was at the track today thrashing the car pretty hard.....got a vibration that feels exactly like a warped/cracked rotor but its comming from the center of the car under the shifter...there then clutch is out or in...under power or coasting sounds like somethings hitting something..no vibration in the shifter it self.....
if i broke somthing you guys probibly broke this too....
Old 10-15-2011, 11:17 PM
BuckeyeZ06
BuckeyeZ06's Avatar
Torque tube...
Old 10-15-2011, 11:26 PM
RX-Ben
RX-Ben's Avatar
Yeah, something is on the verge of completely failing. Drop the TT and check guibo's, etc. Hopefully the TT isn't cracked.
I have a 12mm prop shaft if you need it, and very low mileage guibos.
Old 10-16-2011, 08:42 AM
JimbeauZ06
JimbeauZ06's Avatar
OK I give. What's a "guibo"?
Old 10-16-2011, 10:25 AM
RX-Ben
RX-Ben's Avatar
Hey Jim - I was referring to the rubber bushings that are used as flex joints on either end of the prop shaft.
http://forums.corvetteforum.com/c5-f...tion-test.html
Old 10-16-2011, 01:05 PM
JimbeauZ06
JimbeauZ06's Avatar
[QUOTE=RX-Ben;1578972140]Hey Jim - I was referring to the rubber bushings that are used as flex joints on either end of the prop shaft.
Hey Ben,
I know what the bushings are, just never heard them referred to as "guibo".
Old 10-16-2011, 01:22 PM
JETninja
JETninja's Avatar
WA Events Coordinator
That's cause they are not Bushings, that is a Guibo. My M3 also has one, it's a fiber reinforced rubber vibration and driveline shock isolator. Depending on age and use (replaced one on my M3 at 120K) they start to develop micro cracks and start falling apart shortly after.
Old 10-16-2011, 03:08 PM
TRACKMAN2
TRACKMAN2's Avatar
"guibo" noun from the latin word guiboius meaning do hicky....located between the flux capasitor and the max flow valve
Old 10-16-2011, 03:21 PM
froggy47
froggy47's Avatar
Could be a CV too?
Put the car up in the rear & rotate the drive assm. & listen/feel.
Old 10-17-2011, 09:42 PM
TRACKMAN2
TRACKMAN2's Avatar
torque tube bushings/bearings were toast front really bad rear better but need replaced....
Old 10-17-2011, 09:48 PM
RX-Ben
RX-Ben's Avatar
Want to make a deal for mine? <5k miles (8mos old), orig from GM.
Old 10-17-2011, 10:28 PM
TRACKMAN2
TRACKMAN2's Avatar
just bit the bullet (again) took it to the dealership..my budy there is taking care of me i need the car back asap for a meeting with a lady with a viper at beaverun...... ps DONT TELL MY WIFE SHE'LL KILL ME!!!!!!!
To first issue with the c5z
Quick Reply: first issue with the c5z
