C5Z stoptech st40 wheel fitment
Old 10-18-2011, 11:39 AM
zslow6
5th Gear
zslow6's Avatar
Default C5Z stoptech st40 wheel fitment
im going to be setting up my 01 z06 for road racing this winter and was trying to figure out what wheels will clear the stoptech 14" front bbk kit. i did some searching but couldnt find much info. i had a lot of issues finding wheels to fit my s2000 with the stoptech kit. im not looking to spend an arm and leg for hre's or forgeline. i appreciate any/all help!
Old 10-18-2011, 11:46 AM
spazegun2213
spazegun2213's Avatar
the c5z rear wheels fit with no problems. Thats what I'm running all the way around.
I think there are some other knock offs that work as well.
Old 10-18-2011, 02:43 PM
ccj
ccj's Avatar
I run (4) C5Z rear wheels all around and they fit with no issues over the Stoptech ST60 front/ST40 rear calipers/rotors.
On the street I have a set of Fikse Profil10's they fit just fine as well.
TSW Nurbergring wheels should fit, CCW C140's will definitely fit.
Old 10-18-2011, 02:57 PM
jawfixer
jawfixer's Avatar
I have same brake kit and run C5Z rears around but I do use a spacer up front for the ST60's--they will clear without but feel better with them. TSW Nurbering do clear without issue--have them too and have set of Forgelines--expensive but great wheels--the stock C5Z wheels are light and are good bang for buck if u can find them.
Old 10-18-2011, 05:08 PM
Z06phile
Z06phile's Avatar
I have the ST40 on the front of my C5 Z06.
Here's what I've used:
Stock rears
SSR GT-7H
iForged Aero with BBK offset
iForged TE10
I've seen guys using the Mallet 396 wheels with them too.
Old 10-18-2011, 05:38 PM
geerookie
geerookie's Avatar
TSW Interlagoes will also clear.
Old 10-19-2011, 10:29 AM
zslow6
5th Gear
zslow6's Avatar
thanks i appreciate all the help! does anyone think id have a problem with 18x10.5 replica c6z wheels? or does it really depend on the brand? its from oewheelsllc.com. never really looked at them but a dealer out here buys from them to replaced damaged wheels said they are decent wheels.
Old 10-19-2011, 12:33 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
replica 18x10.5 C6Z wheels will not fit, the spokes are much thicker. I've not tried a C6Z replica.
To C5Z stoptech st40 wheel fitment
Quick Reply: C5Z stoptech st40 wheel fitment
