LG Motorsports G Stop 6 Piston Wilwood Brake Kit w/ Slotted Rotors & FREE SHIPPING!
Supporting Vendor
St. Jude Donor '11
Kit w/ Slotted Rotors & FREE SHIPPING!-$1599
0% Financing for up to 1 Year Available on all LG Parts purchased from TPS!
Have you always wanted to improve your brakes BUT didn't want to get new wheels to fit the larger rotors? We have the solution for you.
LG Motorsports has done it again with their G Stop 6 Piston Brake System! Even fits most 17" wheels including the 17" C5 Z06 Wheels! This great package allows use of your factory C5/c6 front rotors.
As a SPECIAL BONUS we throw in a set of TPS Slotted Front Rotors absolutely free!
Package Includes
**Wilwood SL6 6 Piston - Full Width Calipers (Black)
**TPS Stainless front brake lines
**LG Motorsports brackets with hardware
**Package comes with your choice of Q or E pads
BRAKE PADS AVAILABLE
PolyMatrix E
Light to medium duty road racing and track day events.
Drag racing with iron or steel rotors.
Performance street category competition.
PolyMatrix Q
Disc brake conversions on street rods, muscle cars, custom show cars, and all moderate performance applications where low noise and dust are important.
PolyMatrix H
Great pad track use. Track use only as they are noisy
Here is a picture of the G-Stop Kit with cross drilled rotors (NOT INCLUDED)
Package Includes
PolyMatrix E
PolyMatrix Q
PolyMatrix H
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...Mike Mak
I bought a set of these used a few months back... worth every penny. I ran comp school and raced at VIR two weekend ago and was very happy to have them in place. The best part is the 20mm thick pads. I'd have gone through a set of OEM pads on Friday in Comp School alone. With the Wilwoods and Carbotech XP12 pads I still have over 1/2 the original pad thickness after four 40 minutes sessions in Comp School, 2 sprint races Saturday (25 minutes), and a one hour "fun race" on Sunday.
Is it straightforward to move the stock front brakes to the rears while replacing the fronts with this set?
However there's no need... it would mess up the brake bias and add rotational mass.
Supporting Vendor
St. Jude Donor '11,'13
Yes we do
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Do you have any data comparing these to stock calipers such as clamping force, pad surface area, etc? Since they use stock size rotors I need to know if the results/cost is worth while..
ie; 10% more braking power would be great or would I have to go bigger to get that much. Also I run front calipers on the rear.
Joe
Joe
Joe
Joe
Supporting Vendor
St. Jude Donor '11
Joe
Joe
pad surface is not the end all. Caliper stiffness is what they offer. Thicker pads last longer and wear more even so you end up saving money. Better than stock in the later laps. I doubt they stop better than a NEW set of OEM but they are better on track and worth the money. They are great for the price I had may be the first set from LGM. I have SL-4 WW on rear with 13 rotors on rear. You can modulate them better as they are more consistent in feel than a used spread OEM caliper. Thermo-lock pistons are a great addition. 7420 pad shape is arguably the most common pad around with tins of compound choices. I like H from WW I never tried A but never felt I needed the A.
The kit is available with the following 2 packages....
#1-Lines, pads, rotors, calipers, and brackets
OR
#2-Lines, pads, calipers, brackets, AND NO ROTORS.
OR
Your lines will not work with the Wilwood calipers as the have different ends.
I don't know much about the Hardbar/ AP setup BUT I don't think the AP/ Hardbar system can use stock rotors...If that is the case the LG/ Wilwood system is alot more cost effective.
Joe
Joe
