Lower Oil Temps with Radiator
Car is a stock C6Z06.
One of my track buddies says his oil temps dropped 20* when he added a larger radiator. Is this possible?
Recent track day with 60* ambient had my coolant at 217* and oil at 260*
DH
DH
Absolutely !! A quality dual core aluminum radiator such as a DeWitts or Ron Davis will do wonders for your cooling. Some have integral oil coolers, but for best cooling, I would recommend a separate stand alone oil cooler. I have a Dewitts radiator and a DRM stand alone oil cooler and can run all day at VIR in 100+ degree ambient temps. Extra cooling keeping temps at 270 for oil and 220 coolant.
Yes there is no question bigger cooler = cooler temps.
The C6Z06 already has a large external oil cooler.
My question is wether adding just a larger radiator can lower the OIL TEMPS significantly ????
DH
Howie, have you considered adding a bigger oil cooler? Don't you still have the sotck Z06 cooler? I don't know which would work better, but it seems like it might be higher value to add better oil cooling. I would be interested in other peoples opinions. I have been seriously considering adding a DRM oil cooler before adding a radiator.
Charley
Charley
When I bought my car it was set up with a larger radiator and a seperate liquid/ liquid oil cooler. My oil has never been over 238 at the track and normal driving it is at cooant temp of about 200. I never ran the car with the stock set up and don't know how the liquid/ liguid set-up compares to a air/ liquid set-up, maybe others can chime in. Here is the link for the liq./liq. set up: http://208.109.215.220/files/laminova.pdf
Charley
Charley
One of the guys at ACS told me he got a drop of 20* in oil by just doing a larger radiator. If so thats all I need to do
I'm just not sure I am buying it ?????????
DH
If possible I want to leave the oil lines as is. I think a different oil cooler will mean new oil lines
DH
DH
He may have done a bigger oil cooler in addition to the radiator.
I have the DRM kit in my C5Z and last weekend with u saw peak oil temps of 243 and coolant 208.
Ed
It was Garreth, just radiator, no oil cooler. But he does have ARE oil system ...... we didn't think that would cool oil when we were talking about it.
What size is your oil cooler compared to the stock one in my Z06?? Your oil was 20* cooler and your coolant was 9* cooler. But its summer time that I'm worried about. If my temps stayed like this in summer I wouldn't do anything.
And how come you haven't signed up for a free burger at WSIR with me ??
DH
Ed
DH
DH
I have the C6Z oil cooler in my C6 LS3 Vert w/F55 (no factory oil cooler) and experienced a 20 degree drop on track vs no cooler. With the cooler in the summer (105 degree's @ Chuckwalla) if I ran in 3rd a lot I would still see 280 on oil & 220 on water.
In my C5Z I have the DRM "Track" version which is a Setrab 25 row cooler, I would estimate that this is a 40 degree reduction in oil temps vs a stock C5Z which did not come with a cooler. Hottest day I ran was @ Streets of Willow in 111 degree heat and I maxed at 265 oil / 215 water, most other cars were overheating both oil and water and went home by noon.
So, I would estimate that the DRM kit w/Setrab (model 625) would be worth a 20 degree reduction in oil temps vs the stock C6Z cooler and put you in the 250 max range. You have more oil with the LS7 dry sump so would take longer to heat up the 10Q, and then more heat to maintain the temp.
Gareths extra capacity would help as well, since it would take more energy to maintain the a higher oil temp. Not sure how much more his system holds vs your expanded tank.
One thing to point out is that in 50 degree temps your oil will not get above 155 degree's on the freeway. I loosely wrap my cooler in aluminum foil and will see 190 degree's when wrapped. Joe P and I have the exact same DRM kit and show the same temps. He was able to run double sessions @ ACS with his brother driving and he also maxed at 243 oil. In the past he would easily get to 300 if using 3rd gear and revving out.
I now watch oil pressure only on my HUD as my oil and water temp are well below concerning temps.
Now ask me about my "CRACKED" Front DS Rotor and the thump, thump,thump ride home ....
I will be East for the Dec track day, so although the free burger sounds good ...., maybe NJMP in December or PBIR in January 2012.
Ed
DH,
Have you done a Blackstone oil analysis ?
I sent my sample out today, with my lower oil temps I felt it should be ok to not change as often as when I would hit higher temps in my C6.
This oil has:
- 5 Track Days
- 3k Miles
- 62% Oil Life Remaining (as per DIC)
- Max oil temp was 265
I will share the analysis when I get the report. This motor (stock LS6 20 k miles) has never been on track without the DRM Oil Cooler. I am hopeful that it shows normal street type wear and will allow me to run 6 track days or so between changes.
Ed
This oil has:
- 5 Track Days
- 3k Miles
Ed
So, not quite apples to apples as the LS6 does not generate the HP / Heat that the LS7 would.
Ed
Ed
From experience I know a couple extra quarts of capacity does not change the oil temps on track.
I used to run the Setrab on my C5.
Did the thump, thump, thump home once before
Too bad about WSIR. I wanted you behind me as I entered turn 8 so you could check for oil slicks ..........
DH
DH,
This oil has:
- 5 Track Days
- 3k Miles
Ed
This oil has:
- 5 Track Days
- 3k Miles
Ed
Now that I am running Mobil0w40 I'm less concerned about oil. It gets changed with 2-3 track days.
DH
DH
DH
