trailer hitch
Old 12-06-2011, 01:54 PM
1stz51
1stz51's Avatar
Default trailer hitch
Searched high and low but could not find any info.
I have a 2007 Z51 equipped,does any on make a
hitch to fit. Curt Mfg. says it will not and I learned the hard way
hitch hits sway bar hard. Thanks for any info
Bill
Old 12-06-2011, 04:28 PM
RDnomorecobra
RDnomorecobra's Avatar
this fits only a base model (non z51)? http://www.etrailer.com/hitch-2007_C...t_Corvette.htm
Old 12-06-2011, 04:49 PM
72Vega
72Vega's Avatar
I have an 05 Z51 coupe. Friend modified the Curt hitch to fit around Borla Stingers. Uses same 4 mounting points. Close fit to sway bar, but no problems. Pulled a 4' Harbor Freight trailer (5 track tires +tools) to VIR, Mid Ohio and Putnam this season. Ran like a champ with no issues. Curt hitch doesn't work with the NPP OEM exhaust.
Old 12-06-2011, 11:04 PM
1stz51
1stz51's Avatar
Thanks 72 Vega, thats what I am in the process of doing. It should clear
sway bar by 1/4 to 1/2 inch
Old 12-07-2011, 12:00 AM
Dirk Miller
Dirk Miller's Avatar
Default sure fits my NPP (dual mode exhaust)
Maybe the Curt doesn't fit easily, but it sure works in my '08 C6 w/ Phadt sways. Last winter, I put mine on in my garage using jack stands.
Picture can be seen by going to :
http://s1111.photobucket.com/albums/...with%20hithch/
I encourage others to do the same.
Old 12-07-2011, 07:19 AM
72Vega
72Vega's Avatar
To OP -- If you use the Curt plug and play wiring harness, the instructions that came with it are incorrect for grounding. I used the flat silver grounding strap that runs along the outside of the rear bulkhead as a ground. Works fine
Old 12-07-2011, 09:38 AM
1stz51
1stz51's Avatar
Thanks again 72Vega haven't got that far yet but will do
To trailer hitch
Quick Reply: trailer hitch
