SS Lines - Teflon Tape?
Old 05-29-2012, 10:44 PM
SunnydayDILYSI
SunnydayDILYSI's Avatar
Default SS Lines - Teflon Tape?
I just ordered Russell SS brake lines. Install looks like it is just a bolt on, but I am wondering if I should use teflon tape to prevent leaks. Any recommendations?
Old 05-29-2012, 11:48 PM
Dirk Miller
Dirk Miller's Avatar
I am not sure about the Russell brake lines, but last week I installed Stoptech ss lines on my C6. These had flare fittings on one end and banjo fits on the caliper side. Both of these use straight or parallel threads where the seal is not on the threads like NPT (national pipe taper). Pipe fittings use tapered, interference threads and need teflon tape to make the seal. I presume the Russells are similar to the Stoptech and if you use teflon tape you will contaminate your brake fluid and/or create a leak.
Old 05-30-2012, 12:43 AM
mgarfias
mgarfias's Avatar
Teflon on tapered threads only.
Old 05-30-2012, 08:30 AM
JDIllon
JDIllon's Avatar
I would never use any type of sealant or Teflon tape around the brake system for fear of getting pieces of it in the system. The seal is not made by the threads on brake system connections. Just my .02 If it works for you that's great. JD
Old 05-30-2012, 09:58 AM
ScaryFast
ScaryFast's Avatar
This.
No tape or thread sealer on brake lines. These are for specific thread types (NPT), not just any bolt that seems like it needs it.
Brake fittings are NOT tapered and require nothing. The seal is provided by the fitting type, flare or ISO - look at the little bubble inside the female end. The seal is in that flare, not in the threads. Don't overtighten as that can crush the flare and ruin the seal.
Old 05-30-2012, 10:08 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
Do you guys wrap your ss brake lines? I had a ss remote bleeder line develop a leak last year. Just curious if dirt can get in there and degrade the hose? Would wrapping lines in tape be overkill?
Old 05-30-2012, 05:20 PM
victorf
victorf's Avatar
Originally Posted by ScaryFast
This.
No tape or thread sealer on brake lines. These are for specific thread types (NPT), not just any bolt that seems like it needs it. The tape or goo contains teflon and acts as a lubricant, it allows the tapered threads to screw in farther. It's not really a "sealer" as the name strangely implies...
The information in regards to NPT and purpose of teflon use on your first sentence is not true! Where you came up with that information?
Without going into to much details:
NPT, first of all is an interference taper fit. However, it is impossible to have perfect leak free fit without help. That is where teflon tape or PST from Locite comes in to filled the creavices between the interference male and female threads. So, they are indeed an sealer and their use will not enable the taper fit to screw any deeper than the interference designed NPT fit standard!
Teflon tape all though good but has many pitfalls if incorrectly applied.
Locite PST w/teflon is far better than tape, user don't have to concern with direction of wrap or problems caused by shred tape. It is anaerobic, use sparingly, the suspended teflon particulates will completely fills the voids between correctly tighten threads and provides an leak free seal.
Web information is dangerous when it is not fact based!
Old 05-30-2012, 10:46 PM
StKnoWhere
StKnoWhere's Avatar
You can use nylon spiral wrap to help prevent abrasion if that's what you mean?
Cale Kastane, a mid atlantic instructor, was killed a few years ago at Summit Point Raceway at a far too young age due to brake failure. Don't take chances if you don't know what you are doing.
Old 05-30-2012, 11:10 PM
SunnydayDILYSI
Thank you for the replies. Seems like some have installed SS lines without a teflon sealent and have been successful. I'm going to give that a shot. If anyone has installed Russels without a sealent and had a very bad day, please flame now.
Old 05-30-2012, 11:33 PM
travisnd
travisnd's Avatar
If you're installing OEM style lines using banjo bolts then no teflon tape/sealant is needed anywhere. The caliper side seals with copper crush washers and the line side seals via the taper on the fitting ends.
However, if you're using AN lines (no banjo bolts) then the adapter that threads into the caliper uses a dab of thread sealant.
I run Wilwood SL6Rs up front and the adapter that threads into the caliper body is NPT thread and calls for some sealant.
http://www.tceperformanceproducts.com/assembly-tips/
Originally Posted by "AN" ADAPTER INSTALL
Wilwood calipers come with a 1/8"npt (national pipe thread) inlet on the inboard side of the caliper. Your kit is supplied with adapter fittings for the fit of -3AN Stainless Steel braided hoses.
Install the adapter fitting as shown using a small amount of Teflon tape or similar Teflon sealant. Apply this to the larger end of the fitting leaving the cone end dry for the hose to be fit too.
The adapter fitting should be tightened down about half way on down its thread. This can be done with a 7/16 box wrench or socket. If checking torque the net result is about 11ft lbs. Pipe thread is tapered however so it can be forced in deeper if you continue to turn it. Some kits may be supplied with 45 or 90 degree fittings which will require you "point" or "index" the nipple to it's final location.
To SS Lines - Teflon Tape?
Quick Reply: SS Lines - Teflon Tape?
