Need some advise
Need some advise
I have a 2007 base outfitted for mostly track. Headers, tune, z06 brakes, brake coolers, 34 row cooler with 178 theromstat on oil cooler Dewitt's radiator with built in oil cooler not using
Concern About transmission and rear diff so I am thinking of running lines if possible from transmission to Dewitt's oil cooler if possible any idea. Do I need a pump I know I need one for rear diff found a set up I think will work for the diff. Advise
yes you will need a pump for the trans. Since I would asume you dont have a Z51, you would need a pump that is fitted on the Z51 from the factory
I believe it is just blocked off from the factory on a non z51 car.
I would research it more, but I believe that is the deal.
Or you could just do an inline pump with a thermostat switch or something of that sort.
