Tire Wear Question 2.1 Degree Camber
Old 08-12-2012, 08:52 PM
Cyclone09Z06
Support Corvetteforum!
Cyclone09Z06's Avatar
Default Tire Wear Question 2.1 Degree Camber
I am running 285/335 NT05' on a stock 2009 Z06 with T1 sway bars. I put in 2.1 camber with 0.16 degree total toe in the front and 1.7 camber with 0.32 total toe in the back. I love this set up however my front tires are wearing fast. I am eating up the inner tread on the outer edge. I thought the outer tread would be worn more but it is not. Is this tire pressure? I try to keep them at starting session pressure of 32 they get up to 37 by end of session. I do have to drop 2 pounds every session as the day goes on. I am thinking of swapping the tires before my next outing (Sebring 08/18 with Chine). i was also thing about putting the front at 1.7 camber. Any Ideas?
Thanks, Frank
Old 08-12-2012, 10:32 PM
Lawdogg
Lawdogg's Avatar
I ran -2.8 on the front with 0 toe and my NT05s did the same thing.
Old 08-13-2012, 10:49 AM
FASTFATBOY
FASTFATBOY's Avatar
Mine do that on my Z28 with 1.2 camber in the front.
This looks to be normal as the center tread is a squared off edge and it eats it down pretty quick.
I dont flip them on the rims until they reach the wear bars.
Old 08-15-2012, 09:29 PM
6SPEEDZ
6SPEEDZ's Avatar
First question do you drive it on the street with these tires? If so and you drive it a decent amount that could be why your wearing down the inside of your tires. If you had tire temps that would help to know what was going on.
To Tire Wear Question 2.1 Degree Camber
Quick Reply: Tire Wear Question 2.1 Degree Camber
