Swapping pads but not rotors
![](/forums/images/ranks/500-1000.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Getting to the point where the HP+ just aren't enough for the track. Thinking HP70 for the track and ceramics for the street. Anyone else switch back and forth without swapping rotors? Any issues or tips (e.g., do I have to sand rotors after swap? Re-bed the pads?
Thanks,
Chris
Thanks,
Chris
![](/forums/images/ranks/2k-3k.gif)
I used have a set of pads and rotors for the track and a separate street set and would swap them out for track days. I would then take the street rotors along to the track as spares. Somewhere along the way, I got lazy and just quit driving the Z on the street......
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Jim
Jim
![](/forums/images/ranks/7k-10k.gif)
I switch sometimes to get all the use out of the parts. Some pads don't need to be re-bed but with separate manufacturers it's a good idea. Drive around on the new pad with some street miles, it will clean the rotor for you. Then do the re-bedding.
Thanks,
Chris
Thanks,
Chris
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/100-500.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
I swap between Porterfield R4S and DTC-60 pads with ACDelco rotors. A couple days before a track event I put the 60's in and drive them around. Because they never really get hot they effectively clean rotor surface. I bed them at track or on the way. After event I leave the 60's in for a couple days to clean the rotor again. Once they are loud (squeaky) and all silver (blue gray transfer is gone), I put the R4s's back in for a quiet street ride.
![](/forums/images/ranks/1k-2k.gif)
I do it all the time but it seems to depend a lot on which pads you use. Lately for track pads I've been using the Ferrodo DS1.11 compound or the CL RC8 and neither one of them seems to care that my wilwood street pads were on the car the day before. I have occasionally had judder issues but it was always when using Carbotech pads - they have a lot of redeaming qualities and are great pads but seem to be a little fussy about bedding.
I have swapped out DTC-70, XP-10, XP12, OEM GM, Wilwood BP-10 (street) without problems.
The only time that I have had a problem is with DTC-70 pads on a brand new rotor that was not thoroughly cleaned. If a white rag with laquer thinner picks up any grinding bits, it means it is not clean enough. The metal bits will form a high spot on the rotor and I had massive judder. This happen to me twice before I figured it out.
Supporting Vendor
St. Jude Donor '11,'13
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Thanks,
Chris
Thanks,
Chris
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
The only time I have ever had an issue was with Carbotech pads. Still have no idea why but a brand new set of rotors and pads were destroyed in a day. Followed bedding instructions to the letter, etc.
Never had a single issue prior to or in the 2 years since then with the various Wilwood or Hawk pads, even when swapping.
Carbotech must be doing something right. A lot of folks here swear by them... they just don't seem to agree with my car for whatever reason.
Supporting Vendor
![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
I've read that you can switch between the street friendly Carbo Bobcats and the XP10s without having to rebed. Has anyone tried this out? From the posts it sounds like you do need to rebed if you swap between Hawk Ceramic and HP60/70. Any experience here?
I'm also open to other brands. Please post if you have a good combo. As I'm sure you've experienced, swapping pads is easy, but rotors takes some real work.
![Lurk](https://www.corvetteforum.com/forums/images/smilies/lurk5.gif)
![](/forums/images/ranks/4k-5k.gif)
Carbotech pads are inconsistant, or at least they were years ago.
Sometimes, you get pad transfer, and it creates a nasty vibe. othertimes, no problems at all.
