Want to install Quantum Brake Cooling Kit But Not Sure If I Have Everything I Need
I purchased the quantum competition brake cooling kit some time ago but haven't gotten around to installing until this weekend. Looking at pictures online however I feel like I'm missing something.
When I look at this picture, the piece I'm missing is the black solid plastic duct. The Quantum website says the kit comes with everything necessary for installation but I don't quite see how it would install without that part there. Doing a quick search it looks like people are combining this kit with the DRM brake duct extensions. Can someone please provide some insight on what I actually need before I can proceed with the install.
If it turns out that the Quantum kit is incomplete I would also like to understand how they concluded it's ok to advertise this as a complete kit without any mention of the need for additional parts.
Thanks!
Thanks!
I'm planning to install the Quantum kit too. I'm under the impression that you need to use the Z06 ducts, though I'm not 100% sure.
Lambert's sells a pair of these ducts modified to work with the kit for $60.
What's funny is the OEM C6Z ducts cost like 7 bux each. The modified C6Z ducts are 60 from Lambert and then the DRM ducts are 200. Corvette tax is a B!
there are many threads on this install with good pictures. do a search. I believe you need to buy the duct extensions. probably worth $60. if you start with stock they probably need so much work you run the risk of needing to get new ones to start over.
Received 8,918 Likes
Get the modified C6Z ducts from Quantum. The stock ducts have a 2.5 inch outlet and the Quantum mod increases the size to 3 inches and provides a hose mounting surface so you don't have to stitch the hose to the stock duct. LG sells something similar for about $35 more. $60 is a good deal for taking two cheap parts and permanently adding 3 inches of aluminum tubing to each of them. The tubing alone is probably 15% of the cost.
Bill
Bill
Received 1,253 Likes
2016 C5 of Year Finalist
Bill
Bill
the 15% But I believe this is the way to go to make a nice
cooling package. I tried to do it another way and it did not work
out as well as the C-6 ZO-6 plastic.
You could make the altered duct for less money but Quantum
makes it so easy.
Good luck, let us know how it all turned out.
I have C-5 and bought John's high priced ducts. I am not sure of
makes it so easy.
makes it so easy.
I purchased the Quantum spindle ducts and then made some adapters that mount to the stock duct. Prior to making these I tried pop riviting the SCAT to the ducts...this worked for a while....but was not a very robust solution. This was a much better solution.
Nice job!
I used the DRM "black plastic" ducts with the Lambert spindle ducts and it works well. There are two keys to prevent rubbing. First is location of the black plastic duct. You want to get it just right so the tire doesn't rub on the duct during wheel lock (view photos of installs and some trial and error required - don't be afraid to drill 2ce if needed). Second is getting the hose length just right. If you're wheels are hanging, turn the wheel so that it is fully extended out and cut the hose to fit. That will minimize slack and bulge/rub when you turn the other way.
My Solution
My solution is in this thread:
http://forums.corvetteforum.com/auto...on-c6-z06.html
There's lots of ways to make them work, this just is what worked for me, and still does. No issues with them coming off.
