Air in system after bleed with new phoenix tool
So I tried my new phoenix bleeder to do a reverse bleed, and it seemed like it kept getting air into the system. After the last caliper was done and I tested the car it had a long pedal...
I still have a 1/2 liter of ate blue fluid left and then some cheapo auto zone hd fluid just incase
should I do a normal vacuum bleed to get the air out or is there a trick to make the phoenix work out?
Also how do you gauge how far to open the bleeders? This last time it seemed like a crapshoot for me - half the time the pressure was building up and it burst the filler line off as if the bleeder was too tight (even though it was open), and the other it seemed to leak around the threads while adding in fluid...
I never had these issues with the pos autozone mityvac, but by the 2nd or 3rd caliper my arm felt like it was going to fall off from trying to maintain pressure in that lousy thing.
Thanks!
Thanks!
Thanks!
Thanks!
I prefer pressure bleed (or 2 man).
I might try that for the traditional pull bleed that I will try tomorrow (hopefully that will get the air out)
What bothers me, is that I was using an injection (reverse) style bleed and the pump wouldnt stop getting air into the lines... I couldnt even prime it without some air still being present.
I can already tell this is going to be one FUN sunday...
Thanks for the reply!
http://www.autoanything.com/brakes/7...FY9AMgodQz4ALg
If you are pressure bleeding with this, where is the pressure connection?
I have one, but all I ever did was suction & the pumping (by hand) was a bit much.
On suction it worked once I greased the bleed nipple.
Went to Motive.
This?
Went to Motive.
Went to Motive.
the sequence is just fluid can to back of gun, through gun, to connection on the front of the gun, to the brake bleed screw so its pushing the fluid in (along with the air bubbles).
instead of pushing fluid in, Ill be trying the reverse - Im hoping this will remove the air...
btw I used a rr, lr, rf, lf bleed pattern then found out it was rr, lf, lr, rf for the c6 - not sure if this even makes a difference though...
yep that one
I don't think this new sequence makes a difference, but what do I know of c6, haven't got mine yet.
Try a Motive, you'll never look back. Good bleed first time & done.
Post up tomorrow how you do.
The issue I have with this method is either
a: You push the dirtiest most used up fluid all the way thru the system to the master
or b:
You bleed the dirty out first (normal bleed) then reverse the whole thing and go the other way.
Seems like a waste of effort to me.
Jim
I'd love an aluminum resv and cap... something that can really hold itself on...
The strap down setup does work and can hold more pressure, but is a little scary to look at when it starts to crush down on the resv.
I'm using the one from Motive, ironically, that is GM specific, but being plastic it really can't handle much more than 8 or so PSI before it pops off. I've added an extra soft layer of rubber as a seal, also, to help this.
How much are the aluminum Motive adapters? The one that I've seen was $65.
Jim
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
I like the Motive, too. Never has failed me. I had, at one time, the really expensive Phoenix ($300 or $400) model but it NEVER worked for me. I had used it on bikes, cars, trucks and what have you but it was a total waste of time and money. I used grease, even tried teflon tape for the heck of it but it was a sorry system. A friend wanted to try it, I gave it to him.
The GM & late mustang is $38 plus ship, so looks like I was about $100 low on what I would need to upgrade my garage to all alum caps since I need 4. They (Motive) priced me out of the nice stuff, I'll make do with plastic caps.
Just as an alternative for those who may be reading through after the fact like me, I use a Vacula and the thing is great. Hook it up to your compressed air and it sucks the fluid out so there's no chance of air getting pushed back into the system.
