Looking for a good thread on how to route stock belt through racing seat holes
Old 03-14-2013, 09:09 PM
jd_black_00
jd_black_00's Avatar
2016 C5 of the Year Finalist
St. Jude Donor '12, '14
Default Looking for a good thread on how to route stock belt through racing seat holes
Hi,
I would like to route my stock seatbelt through the provisions provided in my Corbeau FX1 Pro seat. This is a temporary setup until I get my harness bar and harness, but I would like to be safe in the meantime. That having been said, I've been unable to find a good tutorial on how to do this. Has anyone else done this? Any help would be great. Thanks!
Old 03-15-2013, 09:03 AM
c4cruiser
c4cruiser's Avatar
Why would you want to do this? Race seats with openings for 5 or 6 point harnesses are designed to use those harness belts only.
If you try to pass the factory belt through any of those holes, it may not work right in a collision. And if you have to get out of the car quickly, the belt may snag in the hole and not release properly.
You should be able to sit in the seat and pull the factory belt across you and lock the belt in. The belt will work properly that way if it should be needed.
Old 03-15-2013, 09:30 AM
GOTHAM VETTE
GOTHAM VETTE's Avatar
I've installed mine already...but was never able to get a concrete guaranteed this is 100% the absolute only way to install them and if you don't you will die answer.
I think it all comes down to the dimensions of the seats and the passenger and the angles that they put the belts into . If you do a search on how Porsche installs there's you'll even see that they've mounted them differently depending on the style of seat etc.
Old 03-15-2013, 09:33 AM
Hat_Trick_Hokie
Hat_Trick_Hokie's Avatar
You're talking about doing something like this?
If I was going to do a racing bucket, and a 3-point belt, that’s the way I would do it. Seems like it would keep the belt snug against your body, I would just be careful to keep the angles correct so they’re not binding on the openings in the seat.
I haven’t done this personally, but if you have a C5 I would try to unbolt the top mounting point (on the B-pillar) and fish that through the side belt opening on your seat.
Old 03-15-2013, 09:50 AM
jd_black_00
That's the setup I'm looking for. I've read articles explaining why you shouldn't keep the stock seatbelts unless you thread the belt through as shown here. It sounds now like I'm receiving contradictory information. Ideally, I can use the stock belt on the road and the 6pt harness on the track. I'll dig through my manuals and figure out the best way to fish the side belt. Thanks!
Old 03-15-2013, 09:52 AM
Hat_Trick_Hokie
No problem.
You'll need a flathead screwdriver to pop off the cover, and a T-47 torx head to remove the bolt (I believe some people have success with T-50 as well).
Old 03-15-2013, 12:43 PM
Charley Hoyt
Charley Hoyt's Avatar
You will also have to find a way to put the buckle end through the seat also... I tried finding a way to do it with my Cobra Sazuka seat (which is similar in shape to the one pictured) in my C6 and I couldn't find a safe way to do it. Hopefully you will be more sucessful, Good luck.
To Looking for a good thread on how to route stock belt through racing seat holes
Quick Reply: Looking for a good thread on how to route stock belt through racing seat holes
