Stock balancer question LS motors
I know the stock balancer has balance weights. If you replace stock for stock these weights must be duplicated on the replacement (stock) balancer per the FSM instructions.
Question is #1 does GM add the weights with the stock balancer ON THE MOTOR (in other words the whole rotating assembly is being balanced,
or
#2 does GM just balance the balancer after it's manufactured (off the motor)?
If it's #2, why would you duplicate the original weights?
I'm thinking it's #1.
or
The balancer will slip on the shaft during fast RPM changes. If you are not careful the bolt will back out and the balancer will slide off and hit the steering rack. Happened on my brother's 04. There is no key way or anything on the shaft to keep the balancer from spinning. It is just press fit onto the shaft. I know of at least 2 other people that this has happened to also. There is a guy in the Fort Wayne corvette club that has actually made a jig to drill a hole through the balancer and the end of the crank to drive a pin in it so the balancer will not slip. He did this to my brother's car and we haven't had an issue in 2 years now.
I don't know if they balance it on the motor or not, but it would seem counter productive if they know the balancer will slip on the shaft. So my guess is they balance it off of the motor.
the engine is neutrally balanced, I'm not sure why they would add weights during assembly. I always key my cranks during a replacement thought, for reasons stated above.
The engine is not neutral balanced by Chevrolet!
The entire engine assembly is final balanced while it is running and small weights are installed in the OEM balancer.
If you decide to remove the OEM balancer, you should replace it at the exact location from which it was removed. Before you remove the balancer, place a mark on the end of the crank and across from it on the end of the balancer so you can reintall it in the same location.
As others have stated, it is important to properly torque the OEM balancer when you reinstall it. Follow the instructions in the OEM Shop Manual.
So if you replace with an ATI, how does the ATI balance the motor???
that is interesting, GM Racing worked WITH ATI to come up with the proper viscosity joint in their balance, I guess that is to address the slight imbalance.
so when dealers replace the OEM balancers that fall off, I wonder how they are supposed to ever achieve proper balance????
The old/new do have a way to line them up based on holes.
You get a little kit of weights (they are different lengths).
You insert the new weights same as old. You measure how much hole is left to figure if you have a short/med/or tall weight.
You transfer the scribe mark old to new.
Line up the marks & press it on.
Having said all that, I bet maybe 1 in 50 tech's ever goes to all that trouble. On the average grocery getter nobody will ever know or notice.
My balancer just came off last weekend on track. Destroyed the P/S rack and I lost my PS on track. When I get this thing all apart I will pin the crank for sure.
Can you tell if the rubber "sandwich" separated or the bolt backed out or both?
It's a heavy piece, I can certainly see how it would hammer a rack to death pretty quick at high rpm.
Sorry to hear it.
Stock balancer, my p/s pump was whining, or I thought it was whining all morning, but I knew it was going anyway. Then out on track I tried to make a right and it was like I was suddenly driving a tractor trailer. The pulley actually milled it's way into the rack, yet somehow my serpentine belt stayed on despite running way crooked. When I get out to my trailer later I'll post a picture.
Be careful with pinning these - you need to drill a radial hole (see, of course, the ATI crank pin drill fixture kit).
A well-known shop did an axial pin on my ATI damper (without my knowledge) and the balancer was nearly cracked in half when we took it off.
If I didn't lose two piston rings and I was able to actually compete in the last two events of last season, I probably would've lost the damper.
Hey Frog I have the pinning kit. I'll loan it to you if you get it back to me quick, as I'll need it in about 2 weeks. Just PM me your address and it will be on it's way. You can have the 2 pins that are in the kit if you get to ATI and order me 2 more.
For what it is worth I had an arp bolt back out on me. It too ate into my steering rack. The engine was rebuilt just 2 months earlier and the shop swears they used the loctite and proper torque. In either way they were great and fixed everything for free. But after reading this thread i am going to look into pinning the crank.
Question do I have to pull the engine to pin it?
BTW the "Corvette Specialist" that put mine on said he did it all correctly, but I have my doubts. He did reuse the stock bolt for starters.
