Why are Cobalt brake pads so expensive?
Old 04-01-2013, 11:11 PM
Charley Hoyt
Charley Hoyt's Avatar
Default Why are Cobalt brake pads so expensive?
I am looking for track pads for my new Stoptech ST60/40's. I was using carbotech 10/8 but have been having issues with them overheating and smearing. I am considering the Cobalt XR2s but they are a lot mor expensive than Carbotechs. Are they really worth the premium price? Why?
Thanks for the help,
Charley
Old 04-02-2013, 01:24 AM
dvandentop
dvandentop's Avatar
I love them and they seem to last a LONG time, i think they are worth the added cost over hawk and others i have used in the past etc.... not as prone to rust on wheels as easy as some of the others.
you should be pleased with them if you do go that route.
Old 04-02-2013, 06:40 AM
StreetSpeed
StreetSpeed's Avatar
Charley
Have you considered XP16/12 or 12/10?
Old 04-02-2013, 09:21 AM
Charley Hoyt
Thanks, everyone that has them seems very happy with them.
Old 04-02-2013, 09:23 AM
Charley Hoyt
Yes, I am considering them. They are about half the price.
Old 04-02-2013, 09:36 AM
MarkDFW
MarkDFW's Avatar
I run XP12/XP10 and very happy with them. Half the price of cobalt. I can't imagine the Cobalt will last twice as long or stop you any faster.
Old 04-02-2013, 09:46 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Charley
What tire are you using? maybe its time to step up in compound 12 & 10.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 04-02-2013, 11:06 AM
Charley Hoyt
I am using NT-05's...so nothing too sticky (yet)
Old 04-02-2013, 11:07 AM
Supporting Vendor
Are the rears overheating and smearing?
Old 04-02-2013, 11:09 AM
Charley Hoyt
Just the fronts. Keep in mind that my car currently has Z-51 brakes.
Old 04-02-2013, 11:28 AM
Supporting Vendor
Ok do you have cooling ducts?
Stoptech St60 XP12 $240 St40 XP10 $205
Old 04-02-2013, 11:53 AM
YYZ06
YYZ06's Avatar
The other advantages with the cobalt pads is they are compatible with any street pads and they have an extremely wide temperature range.
It was such a pain to change the brakes on my Mustang I used to put them on a home before driving to the track and they'd work fine on the freeway and around town (albeit very noisy). I drove from Detroit to Calabogie Motorsports Park twice, almost 1000 miles per trip, using the cobalt pads and other than being a little more abrasive in the rotors when cold, they were fine.
I use the XR1's front and rear on the Z06 using R-compound tires & cooling ducts.
Old 04-02-2013, 12:42 PM
Charley Hoyt
Yes, I have Quantum Spindle ducts and fog light inlets. Although I just added the Fog light inlets and have only tried them once on a very short track that had a lot of braking and low top speeds
Old 04-02-2013, 01:06 PM
Supporting Vendor
If you want to go with 12&10 I will be happy to set you up give me a call 216-780-8825. I think because your car is heavier this will work better.
Old 04-02-2013, 11:28 PM
Charley Hoyt
Adam has great prices on Carbotech's....but, who has the best price on Cobalts? Where are you guys getting them? And thanks to Jdillon for the email tip, I called them today.
Old 04-02-2013, 11:31 PM
dvandentop
dvandentop's Avatar
Adam has great prices on Carbotech's....but, who has the best price on Cobalts? Where are you guys getting them? And thanks to Jdillon for the IM tip
do you have the pad shape for those stoptech st60??? i might have a good deal for you, i believe they are the same pad shape as an ap racing cp5555 which i dont run anymore.
let me know and i can give you a good deal on some pads i have left over
Old 04-02-2013, 11:58 PM
dvandentop
dvandentop's Avatar
I did some research and found the stoptech St60 is same pad shape as some pads i have sitting around that wont get used again.
here is link confirming it
http://www.cobaltfriction.com/Search...s.asp?Cat=2452
Will sell for $250 shipped let me know I paid $459 + shipping for them
Cobalt Friction XR-2 pads CRB.XR2.AP5/20.0mm for AP Racing 6 piston CP-5555 calipers, will fit Stoptech ST-60 calipers as well they have 3/4 of the pad left atleast these were only used 1-2 track days before i switched to different calipers due to one failing and it was unreasonable to buy just 1 caliper.
To Why are Cobalt brake pads so expensive?
Old 04-03-2013, 08:46 AM
mesospeedy
mesospeedy's Avatar
I know most don't go with a multi use pad, but I typically run hp+ on my car all the time instead of changing for the track. I had good luck with this on my Camaro and planned on doing the same with the GS. I won't be running r comps anytime soon since I don't have an extra set of wheels yet, so I don't see the benefit of running a hard core race pad. Are any of the cobalt pads able to work as double duty pads?
Old 04-03-2013, 11:30 AM
63Corvette
63Corvette's Avatar
I run Stoptech Street performance pads on my ST-60/ST-40 brakes. I run them on both street and track, BUT only on relatively light braking tracks like MSR Cresson. These pads are good for 1300 degrees F, and both my friend (stock Z06 calipers) and I run these pads. They work fine (cold) on the street, and also very well hot on the track with (scrub) Dunlop slicks. I would run real race pads (Cobalt XR2 or PFC-01) for a hard braking track like Eagles Canyon or Road America.
Old 04-03-2013, 04:26 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Best pads on the market today, bar NONE.
We have been using Cobalt pads on the race cars now since 2005, and haven't looked back. You will find them on almost every top World Challenge, GrandAm, and most of the FIA cars now.
Not only do they perform in almost every condition, their life cycle and kindness to the rotors have been very hard to beat.
As to their price...part of it is the fact that they do work so well, but the other part of that is he only does race car pads and does not make 100,000 pieces of each pad a year so it is a bit more limited. Think of them as the Sam Adams of brake pads. Award winning micro brew that caters to the enthusiast more than the mainstream customer.
Quick Reply: Why are Cobalt brake pads so expensive?
