Weight Saving attempts question
Guys, could use a little help or advice. In trying to lighten my car for NASA ST2 class, I have come across 2 items that I don't know what they are or what they do, and if they are essential to keep or not. the first is the door module which is presently mounted on the bottom of my doors, but I don't think this was the stock location. Can they be eliminated on a race car without negatively affecting the operation of the car? similarly, there is a module box presently at the dirvers side rear of the car in a well compartment. The box is about 5 or 6 inches square, and about an inch think with a serious bundle of wires coming out of it, and going into a rubber grommet on the rear side of the fender and disappearing toward the front of the car. Same question, essential? Concerned that I might lose tail lights, fuel pump, or some other critical function. Thanks in advance. Jerry
You don't need the door control module things, removal has the same effect (i.e. none) of removing the seat control module.
Can you take a pic of that other box? I don't think my car has one, based on what you are describing.
Fuel pump is controlled up front, taillights are controlled by your hazard switch (center brake light is controlled by the ABS computer).
the rear box is sitting down in a well at the very back of the car on drivers side. the wire bundle comiing out of it goes directly forward into a rubber grommet (large one) on the rear of the fender down low and looks to head toward the front of the car. I will have access to a lift next week, and be able to see where the wires go. Jerry
Location: If you don't weigh in you don't wrestle Road America
Sounds like your car came with F45 - select ride. Does/did it have a controller on the shifter console for select ride? If so that's the control module for the select ride shocks - I'm assuming that since it's a track car you have already ditched the factory shocks, However if everything is still stock then you would have to program out the select ride with a Tech 2 (if you didn't the car would be limited to 85 mph.)
The other option was to get shock simulators - if simulators are installed then you would probably have an issue if you pulled the module, then you would have to do the Tech 2 thing to program out select ride.
I still have those rectangular boxes, along with the wiring harnesses in my doors, but they aren't connected to anything in the door. The other end of the harnesses go through the door into the car somewhere into the body and they're still connected.
Do those harnesses have to be disconnected somewhere in the body or can the harness just be cut at the door frame without any ill effects to the car?
then you can trace that harness back even farther and dump it
The best reason to trace back harnesses and delete them is because orphan wiring sometimes has power running through it which can lead to electrical fires and short circuits. We have enough problems with our racecars and don't need that issue too.
FBB, I know what you mean about the orphans. I try to find and label everything I can and cap off any loose ends to avoid the hazards you mentioned.
I am constantly amazed, and very appreciative or the excellent advice and willingness to share it on the forum. Mark and others, thanks so much. You have made my processes much easier and less stressful. jerry Stout
What exactly is the ecbm? Is that something that is essential? It sounds essential. This car did have the selective ride control. I was hoping that is what this box was. It now has coilovers so ride control apparatus is not needed any longer. Jerry
ECBM (Electronic Control Brake Module) runs ABS - so you need it. On the ones I know of all that is under the car attached to the rear cradle I think. But model years do vary. The GM shop manual, by year, will show you the layout of each system (once you figure out where in the ^&*_)()&*& it is)
