Race tire question
Old 04-15-2013, 08:13 PM
jcsperson
jcsperson's Avatar
NC Events Coordinator
Default Race tire question
Would you run 305/650/18s on a square set-up with 18x10.5 wheels on a C5 or C6?
Old 04-15-2013, 08:43 PM
63Corvette
63Corvette's Avatar
Yes!!!
Old 04-15-2013, 08:54 PM
jcsperson
jcsperson's Avatar
Originally Posted by 63Corvette
Yes!!!
So the tire isn't too short to run in back?
Old 04-15-2013, 09:01 PM
63Corvette
63Corvette's Avatar
No!
Old 04-15-2013, 09:03 PM
MarkDFW
MarkDFW's Avatar
I thought you had to stay within a certain percentage of the front/rear overall diameter OEM ratio or else the car goes nuts?
Old 04-15-2013, 09:22 PM
BPHORSEGUY
BPHORSEGUY's Avatar
Location: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
You will get errors on your dic w/ the C5!
Old 04-15-2013, 10:00 PM
Hat_Trick_Hokie
Hat_Trick_Hokie's Avatar
Could also run with T/C off...
Old 04-15-2013, 10:28 PM
RX-Ben
RX-Ben's Avatar
Or not. Never had an issue running square (incl with short tires) in an '01.
Those tires are little wide for the wheels, but obviously things get expensive in a hurry when you go with wider wheels.
Old 04-15-2013, 11:10 PM
fatbillybob
fatbillybob's Avatar
I agree no problems square. But we run 315's on 10" wheels in T1. It is certainly not ideal but in T1 the fastest combo was 315 square on 18x10 and 18x11 wheels. A couple guys felt 295x315 was best. I ran both and could not tell the difference. My reason for going square and 315 was to only have to stock one tire size. It is a huge advantage when you got so many sets of wheels.
Old 04-16-2013, 06:35 AM
m3to335
m3to335's Avatar
I've been running 305/660/18 square or 305/660-18 and 305/685-18 staggered on my C6-Z06 on (4) C5 Z rears. It's worked good so far. You all know for sure it's not an issue to roll with 650s square on the Z? That's basically like running front diameters all the way around.
Old 04-17-2013, 01:21 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
I have been running that size on all 4 corners for almost 2 years now on my C5Z06. Usually at about 140, the dic reminds me that I forgot to turn off the tc. Never an issue in competition mode, even at 180mph
To Race tire question
Quick Reply: Race tire question
