C6-Z06 Brake Ducts
Old 05-08-2013, 11:36 PM
mdaniel
mdaniel's Avatar
Default C6-Z06 Brake Ducts
Brake cooling ducts seem to be a popular upgrade.
Curious though as I have a C6-Z06 (2008) and it appears I already have brake cooling ducts.. Is the difference with the aftermarket kits just the hose that runs to the rear of the rotor? If so does that mean all I would need is a hose?
If the full kit is needed then which one should I get? Like everything there are a dozen options .. I see XplosivePerformance has one, as does DRM, Quantum, LG, and no doubt many others as well.
Thanks.
Old 05-09-2013, 09:01 AM
el es tu
el es tu's Avatar
usually they add some pipe to the end of the duct so it will hold the hose better:
you can just run the hose to the brakes like this:
or buy a kit to do this:
http://www.lapponline.com
Quick Reply: C6-Z06 Brake Ducts
