Any thoughts on this splitter?
Old 06-20-2013, 09:33 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
Default Any thoughts on this splitter?
Got this wing:
I have had wing for over a year, but just trying to decide if I want to do this. Splitter is only $239 shipped, so I would have aero for less than $500.
Thoughts?
Old 06-20-2013, 10:09 AM
RX-Ben
RX-Ben's Avatar
You need to go to a front breather if you want a real front splitter.
You can get COT rear wing that actually works for pretty cheap.
Old 06-20-2013, 10:14 AM
Falcon
Falcon's Avatar
How is air going to get to the radiator, there's no opening?
Old 06-20-2013, 10:53 AM
vette6aut0x
vette6aut0x's Avatar
He could tell you, but then he would have to kill you.
Old 06-20-2013, 10:58 AM
Falcon
Falcon's Avatar
Old 06-20-2013, 11:05 AM
waddisme
waddisme's Avatar
That doesn't look like it will still let enough air flow beneath it? They have another one that has vents:
I didn't like the looks of it, plus I don't have vents where they have vents.
Old 06-20-2013, 11:08 AM
geerookie
geerookie's Avatar
If you leave the car a bottom breather with the splitter as shown you will basically defeat the splitter. Venting the hood and adding an under tray behind the radiator would help quite a bit.
Old 06-20-2013, 11:11 AM
geerookie
geerookie's Avatar
This is for looks only. The vents/openings relieve any pressure that may build up on the splitter. Waste of $$$.
Old 06-20-2013, 11:15 AM
Falcon
Falcon's Avatar
That's kind what I was thinking.
Old 06-20-2013, 12:18 PM
froggy47
froggy47's Avatar
What they all said, running a splitter on a c5 requires conversion from a bottom breather to front breather. For function. If it's just for looks, that's another thing.
Old 06-20-2013, 12:42 PM
PushinTheLimit
PushinTheLimit's Avatar
I found the best thing to do was to just pony up the cash for a good splitter and undertray (like ACP) and go with it. It is expensive, but it works good.
Old 06-20-2013, 01:40 PM
geerookie
geerookie's Avatar
You can get the ACP splitter and use something like alumalite to make the undertray, vent your hood and for less that $450 you will have more than enough downforce. These pictures are from last year and I have made some minor changes but you can get the idea.
Old 06-20-2013, 02:16 PM
PushinTheLimit
[QUOTE=geerookie;1584204204]You can get the ACP splitter and use something like alumalite to make the undertray, vent your hood and for less that $450 you will have more than enough downforce. These pictures are from last year and I have made some minor changes but you can get the idea.
Agreed. Just depends if you want a slightly lower weight undertray that ACP offers or an Alumalite one that's suggested. One thing about going with Alumalite, it's cheaper to replace if you destroy it.
Old 06-20-2013, 02:30 PM
Falcon
Falcon's Avatar
Agreed. Just depends if you want a slightly lower weight undertray that ACP offers or an Alumalite one that's suggested. One thing about going with Alumalite, it's cheaper to replace when you destroy it.
FIFY!
Old 06-20-2013, 03:46 PM
NASAblue
NASAblue's Avatar
how are we determining the vent locations? I was led to believe if they are not located properly that it won't relive the pressure effectiviely.
I thought anything back on the flat part towards the windshield made sense, but I've been wrong before.
I like the splitter shown and think it could even be made to be functional with a SIGNIFICANT center vent, but your car would overheat in a second as shown.
Old 06-20-2013, 04:52 PM
froggy47
froggy47's Avatar
[QUOTE
[/QUOTE]
Is there a color theme here?
The house, the tree, the car?
Hmmm.
I like it.
To Any thoughts on this splitter?
Quick Reply: Any thoughts on this splitter?
