Wheel bearings one at a time?
My rr is just starting to have a slight 12/6 movement, no noise or any other symptom. 55k miles.
Does anyone do one corner at at a time (as needed) or all 4 or an axle at a time.
Keep in mind there is no labor savings or price of parts savings by doing multi corners.
I will do diy.
Has anyone found a "regular" SKF at napa/pep/kragen or where is the best price for regular skf.
I don't think I need the race skf although it I did TT or WTW I would. I understand the race is about $100 a corner more.
Thanks guys.
I will do diy.
Thanks guys.
they fail completely at random, sometimes mechanical, sometimes speed sensor. A brand new one could fail after one event even!
I highly recommend replacing them individually, only as needed!
Phoenix Racing has the best prices, like $350 ea. I repl mine as they went bad as there is no time savings doing both at same time. Mine were about 3 mos apart.
Track Junky
I've replaced both stock and SKF as they go bad individually. The only thing to potentially consider is if you are swapping from stock to SKF - you may want to do an axle at a time in that case.
Track Junky
Not for a wheel bearing, not necessary. In fact, the left side takes more abuse than the right side up here in the North East.
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
Haven't put SKF on the rear yet, only the front. But, although I don't realize any play in the bearings at rest, I have noticed rear rotors cracking too often. I have to wonder if there may be play at temperature allowing more stress on pads/rotors with heat from rubbing? Probably time to replace the rears with SKF's.
Track Junky
I have replaced SKF bearings one at a time in my track car.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I always like doing them in pairs when I can. Of course if it is a brand new set and you smack a wall with one corner I don't see the point in doing both front ones.
To me there are a few items on a track car that, for me don't make any sense to go generic on...wheel bearings, brake fluid, brake lines, engine oil, seats, seat belts, helmet......
To me, SKF race bearings are going to be the only way to go.
