Hoosier R6 and storage
Old 08-05-2013, 11:49 PM
Black0ut
Black0ut's Avatar
Default Hoosier R6 and storage
How long can these tires sit (without use) and still be trackable?
I have a set from a track day 2 years ago (Local track disappeared), probably 30-40% wear.
Not so much performance I'm worried about. More like breaking apart on the track or highway on the way home
Old 08-06-2013, 12:18 AM
taken19
Track Junky
taken19's Avatar
If no cracks you should be fine
Old 08-06-2013, 08:20 AM
Feffman
Feffman's Avatar
I've always been told, and do just this, to place the tires in heavy individual plastic bags in a cool, dry place (basement - away from the furnace) to help reserve them.
Feff
Old 08-06-2013, 09:28 AM
heavychevy
heavychevy's Avatar
Not likely to blow out at all. Where you stored them is the most important thing. If indoors, you are good for sure. If they have been in the elements, they will be very slick. But still not likely to blow out. Hoosier DOT's are very tough tires.
Old 08-06-2013, 01:01 PM
froggy47
froggy47's Avatar
Do a very close inspection for cracks and I would check them after a couple or 3 laps (just pull into hot pits) and pull off immediately if you hear/feel any thing weird.
Old 08-06-2013, 01:23 PM
Black0ut
Black0ut's Avatar
okay. Thanks guys.
To Hoosier R6 and storage
Quick Reply: Hoosier R6 and storage
