C5 Alignment Geometry
Old Jul 2, 2002 | 07:23 PM
ifeeltheneedforspeed's Avatar
Default C5 Alignment Geometry
Always thought my C5 FRC felt a little loose on the track. If I pitched it into a corner, it got a little light in the rear and had to counter steer a bit. I also felt like I had to really modulate the power in corners to keep the back end under the car. Well................I checked my rear toe and found it was 1/16th out. No freakin' wonder! I changed it to 4/16th toe-in and driving around town it feels like the rear end stays a little more planted. I'll see at the next track event.
What are you guy's doing and what difference has rear toe adjustments made?
Old Jul 3, 2002 | 06:59 PM
VetteDrmr's Avatar
VetteDrmr
Default Re: C5 Alignment Geometry (ifeeltheneedforspeed)
Boy, that describes exactly what my '00 FRC felt like last weekend. I just got the car a few weeks ago, and I was using the Active Handling in Competition mode, and just assumed my problems were all driver. Think I'm going to check my alignment (at least the toe) before my next event week after next.
Have a good one,
Mike
Old Jul 4, 2002 | 07:34 AM
rcr162's Avatar
rcr162
Toe out on the rear will certainly make the car feel loose.
Is that total toe in on the rear, or per side? Typically I would expect 1/16 toe in per side.
Also ride height and brand of tire can cause these same problems with poor handling. The run flat tires are awful. What is your ride height front and rear measured from the ground to the fender lip, and what are the brand and size tires that you are using?
Old Jul 5, 2002 | 05:49 PM
ghoffman's Avatar
ghoffman
Cruise-In II Veteran
Default Re: C5 Alignment Geometry (rcr162)
No, 1/4 toe in (total) in the rear is correct for track events.
Old Jul 5, 2002 | 07:23 PM
rbeckham's Avatar
rbeckham
Default Re: C5 Alignment Geometry (ghoffman)
Gary - When I have had my car aligned, I have always specified inches in setting toe-out (front) and toe-in (rear) but the printouts I get show toe in degrees (e.g., total toe = -0.21* front, +0.28* rear. Thrust angle is (+)0.01, which doesn't seem right.
How can I translate toe degrees to inches?
Regards, Robert
Old Jul 5, 2002 | 08:37 PM
ghoffman's Avatar
ghoffman
Default Re: C5 Alignment Geometry (rbeckham)
To convert, take the sine of the angle and multiply it times the tire diameter. For example:
for a 27 inch diameter tire, and 0.28 degrees
(sine0.28)(27)= (0.00489)(27)=0.132 or a little more than 1/8 inch (.125)
This is for the total side to side toe. Conversly, to get the degrees from a inch figure, take the arcsine of the toe/tire diameter
OK for further reference,
Toe (in inches) Toe (in degrees)
for 27 inch overall diameter
1/16....................0.133
1/8......................0.265
1/4......................0.531
for 28 inch overall diameter
1/16....................0.128
1/8......................0.256
1/4......................0.512
[Modified by ghoffman, 9:23 AM 7/6/2002]
Old Jul 5, 2002 | 09:58 PM
rbeckham's Avatar
rbeckham
Gary - thanks! For my 25.3" tires, this works out almost exactly to 1/8". I am so glad the alignment folks are smarter than I am.
You REALLY da man!
To C5 Alignment Geometry
