Wanting modding advice for my '93
Hey everyone!
I posted this a little while ago in the C4 Tech & Performance section, but I am looking for a little more in depth responses so I'm here! Anyways, I'm looking to turn my C4 into a great auto-x car, but still retaining the great DD ability that Corvettes have.
So far my plan is;
-Half cage
-Good seats (Sparco, Corbeau, etc.)
-5-point harness
-Camber Brace (just waiting on the UPS man )
-C4 Convertible X-brace to help the horizontal frame flex
-C6 Z06 Brakes
-C6 Z06 wheels
I'm not really concerned about making it fast at the moment. I just want to make it handle and stop until I can build up my skill level. 300hp is enough for me right now.
What do you guys think? What more should I do?
So far my plan is;
-Half cage
-5-point harness
-C6 Z06 Brakes
-C6 Z06 wheels
Not a terrible list. The camber brace makes a LOT of difference on the C4. The half cage will stiffen it up a bit too which is good.
A seat would hands down be my #1 modification after the basics of good pads, fluids, etc are taken care of.
What trans? What rear?
My opinion that if you are going to do brakes, I would go with the Wilwood SL6 on a C4 as opposed to the C6Z setup. It's reasonably priced and you have a ton of much more affordable pad options with the common backing plate. Depending on what you are doing, the C4 J55s could be sufficient for AutoX and save some cash.
As for wheels, I'm not sure about the backspacing/fitment of the C6Zs on a C4 unless you are going to the non OEM look-alikes that are made for the C4.
May I ask why not? Is it the price that's driving you away? I'm not dead seat on the Z06 brakes, I'm just going around that size or in that ballpark. I have considered the C4 J55 brakes, but I don't want to change them and realize that I want more stopping power. I would rather have too much than too little.
I'm not saying don't upgrade, I'm saying don't get the C6 stuff. Those padlets are stupid, the Wilwood SL6R is a very reasonably priced caliper upgrade. 1 piece pad selection for the C6 calipers seems to suck too.
I know you weren't saying not to upgrade, I'm just wonder why not the specific C6 hardware? I'm sure once I got close to buying my brakes my research would have persuaded me away. The experience I've had with Wilwood is that they are very good quality brakes, and would love to have them on my C4.
Can you share what class you want to have it be a "great autox" car in?
That will have an awful lot to do with what folks recommend.
I love the handling of my 93 with Bilstein's, Rippe Coilovers with very stiff springs, big sway bars, Rippe FX3 chip, custom offset Fikse's running 315s in the back, convertible cross brace, 383, Kumho Ecsta 700s, etc. but it will never be a great autox car because it would fit in a Prepared Class and it would be tail end Charlie against built B Prepared cars.
Your car is 20 years old so start with the basics. Bushings, Tie rods, ball joints, and hubs. Check all.
30/26 sway bars and some cheap re-valved Bilsteins
Aggressive pads and fluid should be good enough for Autocross to get started.
Matt
Matt
Of course! Starting off stock/close to stock and then going to start adding the fun mods. I'm running Nitto NT555's which are great tires!
