Hoosier R6 PSI? C6 Z06
Old 12-09-2013, 01:36 PM
dapopa9
dapopa9's Avatar
Default Hoosier R6 PSI? C6 Z06
What hot PSI is everyone running their Hoosier R6 tires at on the C6 Z06?
Old 12-09-2013, 03:46 PM
crease-guard
crease-guard's Avatar
36-38 psi hot
Old 12-10-2013, 11:30 AM
c6 zeee06
c6 zeee06's Avatar
I try to keep them 30-32 hot. I seem to lose the back end when the pressure goes higher then that. To get to the 30 mark, I start them at 24ish but that's greatly dependent upon weather. I'm talking about road course temps, not street driving. Good luck.
Old 12-10-2013, 07:41 PM
dapopa9
dapopa9's Avatar
yes guess I should have specified - this was in regards to use on road racing tracks for lapping. Not street driving, drag, or autocross.
Old 12-10-2013, 08:54 PM
BEZ06
Support Corvetteforum!
BEZ06's Avatar
Here's a good Hoosier Tech Bulletin about stuff such as initial heat cycle, optimum tire temps, camber settings, and of course pressure recommendations:
http://www.racetire.com/products/tctips.htm
You can see Hoosier says for a car like ours that weighs more than 3,000 lb, run the R6 at hot pressure of 38-43+ psi.
Bob
To Hoosier R6 PSI? C6 Z06
Quick Reply: Hoosier R6 PSI? C6 Z06
