WTB: Harness bar for C4
WTB: Harness bar for C4 (91-96 and 90-95 ZR-1)
No longer needed. I found a harness bar from a member here.
Thanks!
Thanks!
I just put a Sparco bar in my '87 and the bar sits at the right height so that the shoulder straps are within the recommended 20 degree angle for shoulder protection. This bar also allows for the use of the standard seat belts.
One thing about the C4 harness bars is that there is a 2" difference in width at the shoulder belt mounting points between the 84-90 and 91 and later coupes. What may be more of a concern is if the halo on the ZR-1 body is even wider than either measurement. When looking, you should specify that the harness bar is for a '90 ZR-1.
Only a few of the manufacturers specify the year difference and not sure why Hardbar does not. The Brey Krause specifies their bar does not fit the early model years. It seems like more and more of the companies no longer make the bars for the C4 other than BK, EM, and Hardbar with current advertisement. I'll keep researching.
Thanks again for your input.
Nope. Right now looking at Corbeau A4s because I know they fit, but also researching what else is out there with Recaro, Bride, Sparco, etc. In two weeks I will be attending Tokyo Auto Salon (the SEMA show of Japan) to try out all the seats there and take measurements; I might luck out and find something good and different. Thanks for your thoughts.
I think what he is referring to is splitting the shoulder belts around the upper seat back / headrest. It will allow the upper body to slip between the shoulder belts.
I drove a 91 with A4's, liked them.
In fact, if you come thru my tech line (SCCA), I won't issue a tech sticker for that setup.
What does "mostly" mean?
My personal thoughts on 4 points: What most guys don't think about is that aside from the safety aspect of a sub belt, it's the sub belt length that determines the position of the lap belt when the shoulder straps are pulled tight. If tightening the shoulder straps pulls the lap belt up on to your stomach , it can get uncomfortable on the track.
It's not a big deal on a 1 minute autox though.
Would a shoulder belt retainer be of any use to keep the belts from slipping off your shoulders when using a stock seat? Would the SCCA accept that?
http://offroadpress.com/wp-content/u...iner-strap.jpg
I'm trying to learn about autocross and I think I would like to try it but I would like to keep the stock seats.
As far as 4-point belts, Bill32 is correct, without the sub belt attached and adjusted properly, the lap belt may ride up to where it would not keep your hips from moving forward in a crash or possibly even heavy braking effort like you would see during track days or autocross events that would have some high speed sections.
I don't think I would consider using a shoulder strap retainer even with race seats. The multi-point harness buckle is designed to release all of the straps at the same time. The 2 shoulder belts would still keep your upper body within that part of the harness. In case there was a fire, that's simply one delay in getting out safely.
And, yes, the rules state that the belts must use a single point release.
Also, you can find used race seats for $200. Pulling the stock seat and putting in the race seat is like 10 minutes (once you have the race seat fitted correctly).
Reason I asked is for Stock now Street SCCA auto-x class you cannot change the seats. However, you can run harness bars and harnesses. From a safety aspect I think a better setup is a good thing and and they do hold you in better than the stock 3 point belts.
Sounds like stock 3pt for auto-x.
Swap seats and use the 5/6 point for a track day.
I've looked into the Jet Pilot harness and while expensive it might be the best compromise with stock seats? Thoughts?
But I've never seen it in writing or it the rule book. It's possible that a SCCA inspector did issue a tech sticker for them I guess.
They are approved for NASCAR (which doesn't mean much for SCCA).
If you do run them, you should do some practice runs on getting out of the car quickly (I have the drivers that I coach do this once a year).
Too bad that "Cinch" button on a C4 doesn't lock the shoulder belt too, huh?
Yea, I'd swap seats for your track days.
But, I do run a couple sessions per event in my 92 with the stock belts taking students out and running about 90%. If I was running the car hard and running every session, I'd change seats/belts.
The Jet Pilot president stated that SCCA has approved his belts (dual release).
Thanks for sharing your thoughts and experience as an instructor. Last month I treated myself to the Z06 Experience (1 day) at Bondurant School of High Performance Driving in Chandler, AZ and it was my first experience of taking a car on a track. What a car it is in stock form and I was surprised to see only stock seats/belts. I could see how the car and experience could have been so much more if I was not fighting to keep myself planted (of course because of a my lack of experience too). Thus my decision to get a harness to try to improve my driving abilities as well as increase safety. I should have done it a long time ago after my first experience in someone's BMW M3 years ago and how impressed I was and how much safer I felt.
You're correct about what a harness does (as long as it's with the proper seat). It just makes a huge difference.
There's even a step above a race seat, which is a poured bead seat that's molded to the driver's body, really incredible, your body doesn't move an eight of an inch in one..........but they're mostly for open wheel cars.
Have Fun, Good Luck.
