100 more HP or Coil Overs?
What are the benefits of each option?
(car is 06' Z06 with slight tune, R6's, front BBK (DTC 70's) no other mods)
both could be an option also.
IMHO suspension will give you a much better bang for the buck on the track. A good set of coilovers (LG or Pfadt), Poly bushings, heavier sways, alignment and corner weighting will give you a substantial drop in lap times. It will be a new car and you will have a learning curve before you can effectively use the new much higher capabilities.
The stock 505 HP in your Z is already more than most drivers can use effectively. You can already pass 85-90% of the cars out there on the straight so more is not really needed. Cornering power is where you will really decrease your lap times.
2nd that Agree
2nd that Agree
I did suspension (LG coilovers, sway bars, poly bushings, corner weighting) at the same time I did aero (World Challenge vented hood, front LG splitter, wing). Lap times dropped by about 4 seconds. I did the motor the next year (about 100 rwhp increase). Lap times dropped about 1.5 seconds on typical track.
I am going to be the dissenter here. If it is only between coil-overs and 100 HP I might take the HP depending on the track. 100 HP is a lot, especially the results it will produce at Road America or Auto Club Speedway. At a track like WSIR coil-overs might be the answer, but I think stock Corvette suspension is pretty damn good. Many cars get faster with the coil-overs because other things were changed in the process, namely camber, toe and tires.
If you want the most speed increase of all going from street tires to A6s will get you there fastest if you pardon the pun.
Supporting Vendor
Gary like stated above. Have you ever been passed by a car with much less HP?
Do the coilovers and bushings. Do you still drive that car on the street? Maybe time for a cage if you don't.
And IMO the driver, tires, weight, alignment, shocks, and aero are the better places to spend the money. You are a lot more experienced than me though, so to name a track and say which is better is not something I can do.
Not necessarily in this order, but close:
1. Seat/harness/hans
2. bushings/camber kit/hubs
3. upgrade cooling for engine/trans/diff and upgrade ls7 heads for reliability
4. sticky tires with race wheels
5. data system and video analysis
6. sways/shocks/springs
7. lightweight clutch
8. weight reduction
9. full cage and race license
9. aero
10. competition and practice
More power would not even make my top 10 list with an LS7. Just my opinion.
8. weight reduction
9. aero
Adding power to the fragile LS7 in a tracked car sounds like a terrible idea.
You should get the dry sump tank upgrade. And do something with the heads, but last time I checked there was no good fix for the LS7's appetite for Ti valves (other than adding boat anchor stainless valves).
I would stick to 1-5 on the list above, maybe play with sways if you really want to bolt something on.
For an ls7 not upgrading the oiling system is going to cost you. The 06 still had the small tank and enough testing has shown that running anything sticker than the good years is pulling the pin on a grenade. Simply adding the larger tank along with baffles add insurance for a small cost. Parts should be under $500 and is a one time expense. The exhaust valve issue is still up in the air with strong believers on both sides. Some say there is nothing wrong with others saying it is a time bomb. Sure the truth is somewhere in between but the bad news is if it fails it seems to take the block with it. The wiggle test may help if there is a clearance issue but it does not seem to be a perfect test. Worst news is there does not appear to be a real fix for the issue. Your car and you have the choice to run it as is but be aware the engine is going to be over 10k in parts to repair.
Mine is having the larger tank installed now along with a head refresh. What are the baffles you're referring too?
I do about 4-5 events/year with 2 @ RA. 40k miles on car 5k of them are track miles, so the car is basically a street car. I don't mind the stiffer ride but don't see caging it.
Suspension before power. Think about your total time at WOT on a road course, then realize that your suspension is working every time you turn the wheel, squeeze the right pedal OR the left. I'd do adjustable shocks at a BARE minimum. Once you hit double adjustables, you're only talking another $300-400 to put coilover springs on them.
Remember that with suspension upgrades, your corner exit speeds go up, making the power you have more effective.
That being said, if the car is mostly stock now, you need to do:
1) seat and harness
2) LPE oil tank
3) A6s
4) sways and adjustable shocks or coilovers
5) cooling (brake, oil and engine)
Way down the list) power
1) seat and harness
2) LPE oil tank
3) A6s
Coil overs for sure, they get you around the corners faster than that 100 hp.
Not to highjack your thread, I have a set of Pfadt SA I just took off the car when putting on a set of Penske's. Haven't gotten around to posting a for sale yet, figured I'd wait till after the holidays. PM me if interested.
