Need Pfadt Inverted Shock Adjustment and Swaybar Setting Advice
Old 03-01-2014, 03:02 PM
Chris Edwards
Chris Edwards's Avatar
Default Need Pfadt Inverted Shock Adjustment and Swaybar Setting Advice
Hey all, I just installed Pfadt Jerry O'connell sways and Pfadt inverted shocks.
The rear swaybar has three positions for the endlinks. Any suggestions where I should install them? Outer, inner, or middle?
Also, what is a good daily driver shock setting and what is a good HPDE shock initial setting? I understand that adjustments will be made depending on the track, tires, whether it's oversteering/ understeering but I'd like to start out close rather than far.
Thanks!
Old 03-01-2014, 06:13 PM
UrbanKnight
UrbanKnight's Avatar
Middle hole for the rear bar is most popular.
Old 03-01-2014, 09:48 PM
crimlwC6
crimlwC6's Avatar
I have the old pfadt inverted shocks that have 16 or 18 clicks iirc and the o'connell sway bars. I set the shocks at 10 and 12 up to 12 and 16. Swaybar is best to start at outside (full soft) and then middle if you want stiffer rear. Start at 10/12 and outer setting. 2 cents.
Old 03-01-2014, 10:22 PM
Chris Edwards
So you put both front and rear to 12? Or do front 12 and rear 10? Also, do I go all the way in then for full stiff then adjust outward for full soft? Or other way around.
Old 03-02-2014, 12:37 AM
db2xpert
db2xpert's Avatar
The pfadt website is still there, and the install instructions are still there.
Old 03-02-2014, 01:38 AM
Chris Edwards
Thank you. I wasn't aware of that I'll check it out. I thought that maybe the site was being minimalized in some way
Old 03-02-2014, 01:50 AM
crimlwC6
crimlwC6's Avatar
The lower settings are for the front and are softer. 1 is full soft. Iirc clockwise is stiffer. Remember mine are the old version so I don't know if types are the same .
To Need Pfadt Inverted Shock Adjustment and Swaybar Setting Advice
Quick Reply: Need Pfadt Inverted Shock Adjustment and Swaybar Setting Advice
