Oil cooler thermostat & cooler for C6Z road course discussion
#141
Check Improved websight or give them a call, they are a very knowledgeable nice group of guys.
My understanding is all but 10% is bypassed when cold, then opens to only 10% bypassed when hot.
Bypass is by temperature not delta P like a C6Z. The differential pressure bypass is due to the limited size of the stock C6Z lines.
#142
#143
Hypothetical question here.
We get some overwhelmingly hot summer days down here in Texas. I'm wondering if I could add the OEM C6Z oil cooler in conjunction with the upgraded Setrab cooler, separated by a 212* thermostat from Improved, placed after the Serab as a bottom-feeder using a vented steel plate to scoop air in as well as act as a rock guard similar to this:
In theory, I think it would work. It may suffer some pressure loss, which is not ideal, but can be countered with a more potent pump from Improved as well. Would this work, or would it simply be easier to just go with a larger cooler and sell off the OEM pieces? I'm not planning anything in particular, I'm merely spitballing ideas just to provoke thought and conversation on the subject.
#144
Just take the hood off and giver. There is a point when I understand form over function and all that but please don't put that on your car.
#145
Looks like Improved Racing just put out a nice kit.
The brackets look amazingly like Johns prototypes in post #86
https://www.improvedracing.com/oil-c...kit-p-768.html
#149
the kit is $1000 so id like to get it right the first time
http://www.improvedracing.com/oil-co...kit-p-768.html
and the thermostats are $200 a pop plus throwing away the $200 one that comes with the kit if i get it wrong.
http://www.improvedracing.com/oil-co...nes-p-209.html
Improved racing says:
Options
Options
- 180°F Thermostat - Recommended for street use and occasional track use. Recommended for wet sump vehicles.
- 212°F Thermostat - Recommended for race cars that run a higher viscosity oil and must maintain higher minimum oil temperatures. Recommended for dry sump vehicles (Z06 models and Grand Sport Coupes with manual transmissions).
#150
Supporting Vendor
Options
Options
m60gov20 (08-09-2023)
#152
Supporting Vendor
We are also going to be adding the option of using our new thermostat, EGM-114. Depending on your headers, this adapter might provide better clearance. The return line enters the adapter on the bottom instead of the top.
Just FYI everyone, Setrab has the coolers we use for the complete kit on backorder, but we should be getting more in soon.
#153
is the date on your website fairly accurate? im interested in the complete kit.
when the coolers and kit come back in stock is that when you will be adding the EGM114 option? or is it further down the road?
#154
Supporting Vendor
We haven't quite decided how we will deal with adding the option. We don't want to confuse customers too much with too many options. But the reality is the EGM-112 will work best for some headers and setups and EGM-114 will work better for others. We were considering offering only EGM-114 but we recently had a customer tell us it didn't work for him but EGM-112 did.
For the time being, if you decide you want to use EGM-114, just let us know in the order comments and we will adjust your kit. You can also call or email to order.
#155
thank you for you activity/responses in this thread.
ill snap some pics of above my filter and get with you. im running texas speed headers
#156
Options
Can you provide some insight as to why the dry sump cars ( I own a 2013 GS) are better with the 212F thermostat? My car does double duty between street/track but I run stock Mobil 5W-30 so I'm wondering where do I sit.
#157
This makes me wonder as well, as I drive my vette is pretty much a "once-a-week + track weekends a few times a year" GS (dry sump), and I went with the 180* thermostat...
#158
Supporting Vendor
Once the oil is up to temp the engine is under heavy load, and the cooler is getting full oil flow, the lowest temp in the system will likely be the temp after the cooler and not the tank.
So you just have to take into account where your oil temp is measured when you check your temps.
Really, both thermostat temps are perfectly fine and both are safe operating temps for the oil. It's more down to personal preference and what oil viscosity you usually run. But if you have the 180F thermostat, with dry sump on the street you might see your oil stabilize at only 160F because that might be the temp in the tank while the temp at the thermostat is at 180F.
Hope that made sense, lol. It can be a little confusing. Bottom line: both thermostat temps are perfectly fine.
#159
Thought I'd share my set up to add to the data base in this thread.
I have a 09 C6Z. I lost the stock engine and replaced it with a 595 whp engine. I added an a Camaro hood vent, I wrapped the headers I installed a Katech red oil pump, and oil line adapter 10 AN. Plumbed it to a fairly large Fluidyne two pass cooler I think it is 18x12. I added a dewitts radiator with the stock location trans cooler. I deleted the Ac and removed the condenser. The stock setup was VIR numbers. The current setup is Daytona numbers. I expect a little warmer oil at VIR but I don't expect it to get above 250. I am very pleased with the results.
Before
09 C6Z Stock engine
Oil 5w30 mobil 1
Oil temp 275 on track, oil pressure 33-36 on track maybe 18 idling in the pits after the run
After the new set up
Oil is 5w40 Mobil 1
Oil temps 230-235 45-47 psi, 35 Idling in pits after a run
Before
09 C6Z Stock engine
Oil 5w30 mobil 1
Oil is 5w40 Mobil 1
#160
I have a 09 C6Z. I lost the stock engine and replaced it with a 595 whp engine. I added an a Camaro hood vent, I wrapped the headers I installed a Katech red oil pump, and oil line adapter 10 AN. Plumbed it to a fairly large Fluidyne two pass cooler I think it is 18x12. I added a dewitts radiator with the stock location trans cooler. The stock setup was VIR numbers. The current setup is Daytona numbers. I expect a little warmer oil at VIR but I don't expect it to get above 250. I am very pleased with the results.
Before
09 C6Z Stock engine
Oil 5w30 mobil 1
Oil is 5w40 Mobil 1
Before
09 C6Z Stock engine
Oil 5w30 mobil 1
Oil is 5w40 Mobil 1
