LS2 Shortblock w/ all other Z06 Parts, Worthy Combination?
Old 08-20-2014, 06:37 PM
Chris Edwards
Chris Edwards's Avatar
Default LS2 Shortblock w/ all other Z06 Parts, Worthy Combination?
Hey all, I want to build a motor on the stand, then swap it in when it's all built. I have a chance to acquire a low mile LS2 shortblock. I'm aware of the swap parts necessary for the build. I planned to use my C5 Z06 oil pan, ported 243 heads, Fast intake, etc with the LS2 shortblock.
Any thoughts on this?
Old 08-20-2014, 06:52 PM
Apocolipse
Apocolipse's Avatar
Received 1,282 Likes on 927 Posts
Giver
Old 08-20-2014, 06:58 PM
Chris Edwards
Originally Posted by Apocolipse
Giver
Yo no comprendo?
Old 08-20-2014, 07:25 PM
Apocolipse
Apocolipse's Avatar
It means sounds awesome! Take pics and post em up! Good luck with build.
Old 08-20-2014, 08:08 PM
Chris Edwards
I was primarily curious about any oiling passage differences between the two blocks. Many guys are saying that a mild LS6 build is the most reliable HPDE combo, I was wondering if the same holds true to the LS2 shortblocks.
Old 08-20-2014, 08:09 PM
msracing
msracing's Avatar
I just built one, ls2 , stock 243 heads,, better springs and titanium retainer and keepers, fast intake, 60 lbs injectors , LG g5x3 cam callies crank, Oliver rods, J.E piston,,, and a dailey engineering dry sump system ,, hooked up to a Holinger Sequential 6sp gear box.. no flywheel to a 7 1/4 triple disc tilton clutch... it make 477 hp 444 tq at the rear wheels... we built it up this way as an endurance motor,,, and really love it .. i know we could make more power with other heads but wanted to keep it safe ...
we are running it in a c6 race vette,,,We love it...
Old 08-20-2014, 10:26 PM
Chris Edwards
Originally Posted by msracing
I just built one, ls2 , stock 243 heads,, better springs and titanium retainer and keepers, fast intake, 60 lbs injectors , LG g5x3 cam callies crank, Oliver rods, J.E piston,,, and a dailey engineering dry sump system ,, hooked up to a Holinger Sequential 6sp gear box.. no flywheel to a 7 1/4 triple disc tilton clutch... it make 477 hp 444 tq at the rear wheels... we built it up this way as an endurance motor,,, and really love it .. i know we could make more power with other heads but wanted to keep it safe ... we are running it in a c6 race vette,,,We love it...
Sounds like an animal. I don't have any plans to go dry sump tho, so I'd like to hear feedback about ls2's and wet sump setups.
Old 08-20-2014, 11:41 PM
Last C5
Last C5's Avatar
I'm currently putting a 408 LS2 stroker together with a wet sump. I've been told by several engine builders that the wet sump will be OK on the road course with restricted flow push rods, drilled lifter trays, and an accusump for little extra insurance. Time will tell.
Old 08-20-2014, 11:50 PM
Chris Edwards
I plan on all those same supporting parts. I'm just wondering if the oil passages on the LS2 are somehow inferior to those on an LS1/ LS6. Read a few posts about that, but I'm not sure at this point.
Old 09-20-2014, 01:30 PM
crimlwC6
crimlwC6's Avatar
I'm doing about the same with an LS3 block. Any update?
Old 09-20-2014, 01:45 PM
Chris Edwards
You're putting 243s on an ls3 block, why?
Old 09-20-2014, 09:41 PM
crimlwC6
crimlwC6's Avatar
317 heads on an ls3 block w/ ls2 crank. Ls2 crank so that it works with ls1 computer. Going in 99 c5.
To LS2 Shortblock w/ all other Z06 Parts, Worthy Combination?
Quick Reply: LS2 Shortblock w/ all other Z06 Parts, Worthy Combination?
