Alignment methods compare and contrast
#162
Resurrecting this old but fantastic thread. Has anyone tried the Longacre tire scribe and toe gauge to check toe? In theory this sounds like an easier way to set toe but I'm clear how the scribe process works and how accurate that is.
#163
that is what alignment shops used before lasers. the wheels need to be off the ground the scribe is placed against the tires rotate and it scribes a line around the tire. set it back down and measure front and back between the lines.
#165
Received 8,928 Likes
