about leaving a6's out in the cold for the winter( in shed), if they are not on a car, just sitting on a bench will the cold hurt them? i have seen them get damaged being used in under 32 degrees, but sitting off the car? any one know?
Supporting Vendor
Unfortunately, my building is quite old and cold. And I live/work in western PA. Mine see freezing temps. I'd recommend simply you donm't drive on them when that cold (if you can help it, we've had events where it was that cold to start). You can crack the rubber, it's not an all season or winter tire. Just have them off the car and you'll be ok.
thank you all
Max G’s
Supporting Vendor
I'll be there, with a non-failed master cylinder this time! Looking forward to it, ought to be a battle in SSR, I know a few other fast guys are coming to end the year right.
Received 8,919 Likes
The tires can get quite cold when being shipped around the country in the winter time. I don't believe the manufacturers hire heated trailers to move a truck load of tires from the plant to the various sales outlets. Then how many tire dealers have heated tire storage. I have seen plenty of non heated warehouses or in some cases old 18 wheeler trailers used as storage facilities. Just try to avoid running them when they are cold although that can be tough if you are at the Glen for a track day at the end of April with 32 degree ambient temps and snow flakes flying.
Bill
Bill
