View Poll Results: Which foot do you brake with on the track?
Right foot braking
63
66.32%
Left foot braking
32
33.68%
Voters: 95. You may not vote on this poll
Right foot or left foot braking?
Gasoline Addict
Which foot do you mainly use? Obviously, when heel/toeing you have to use the right foot (except in an auto).
Vote your preference...
Also, any tips on how to start left foot braking for those that don't?
I use my left foot on approach to corners that only require a speed change and not a downchange.
Similar to heel and toe every time you drive an automatic on the street you should be using your left foot to brake.
I got really good at it when we had the GTR for 2 seasons. Tons of trailbraking used in those to get them to turn and it made the transition to power seamless.
Hardest part in the Corvette or Viper is you are using your left foot on the clutch and brake and it requires some getting used to. The tendency is to smash the brake because you don't have the necessary learned muscle control to press the clutch deftly and then use a sensitive pressure on the brake.
Practice is the only way I became half decent at it.
Max G’s
AutoX left foot brake, left foot on brake and right foot on the throttle at all times. On track lapping I left foot also, but keep my left foot off of the brake unless need to brake. I practice every day in my daily driver on the street. It is now instinct for my left foot to go to the brake in panic stops or any time I apply the brakes.
Tip: practice on the street every time you can this winter and spring before going to the track to work on muscle memory. I panicked on the track one time when I first started doing left foot. Went to right foot and left foot brake at about the same time at a turn and got me and the car all unbalanced. This is coming from a auto driver that had been right foot braking all his life
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes
Really a helpful technique when you need to shift weight to the front tires for more equal load share between the two if you find yourself pushing really badly while allowing continued throttle float. Also, can be helpful when at the limit in a somewhat compromised misaligned suspension. In other words, most needed when at the limit and you need corrective action RIGHT NOW! Thus, you really need to be really good at it, have a well trained sensitive left foot and not prone to confusing clutch pedal for brake pedal....seriously, it happens.
SouthernSon has very good points. I left foot brake in the GTA car, no clutch needed other than when starting off and coming to a stop. Right foot is blipping throttle on downshifts. It's really nice to be able to put a little weight on the front when under throttle. Learning was a humbling experience! No power brakes, no abs.
It is very simple. If you are not using the clutch other than when starting off, you can left foot brake. With regular manual gearbox left foot braking doesn't make any sense unless you are driving FWD rally car on gravel or snow.
In my opinion, you should left foot brake.
You should also NOT hell and toe.
Slowing down at maximum is not the time to be wiggling your foot.
You needed gears to slow down 40 years ago with drum brakes, now you just want to be in the right gear to come out of the corner.
Tips.....Practice,
Drive the track in a higher gear so you do not need to shift.
Do exactly the same with your left foot as you do with the right foot brake with out shifting.
Off the gas, on the brake. off the brake, on the gas.
You will find very soon you will be bringing up the gas pedal just as you finish the braking.
You will then be ready to do shifting.
There are some who disagree with this approach
Received 8,928 Likes
Anybody ever remember the videos ESPN used to show of Rusty Wallace's footwork at Watkins Glen. He switched from heel to to left foot braking and back plus shifted without using the clutch all the way around the track. If you blip the throttle correctly you can shift without using the clutch so that leaves your left foot free to brake.
Bill
Bill
OK,
Tips.....Practice,
Tips.....Practice,
OK,
Tips.....Practice,
Tips.....Practice,
OK,
Tips.....Practice,
Tips.....Practice,
As I understand it constant mesh transmissions don't like to be shifted without disengaging the clutch as it damages the synchros. Dog box non synchromesh transmissions with straight cut gears like are found in stock cars from what I understand can and are shifted without the clutch.
Racingswh: driving/shifting a Jericho is a blast! For upshifts you just back off the throttle for a hair, shift and keep on going. Downshifts are handled with a blip of the throttle.
Gasoline Addict
OK,
Tips.....Practice,
Tips.....Practice,
Bill
Bill
I build a lot of these gearboxes. They shift so nice.
You can see the dog ring on it's slider here in the middle of the gear stack.
I have to say I do really like all the foot work and rev matching that you need to do in order to be quick in any of these cars and not nearly as big a fan of the dilution of driver skill that's taking place when driving the newer nanny filled stuff. As I mentioned driving the GTR was really boring for me. Even though ours was really fast I never felt like my driving ability was being tested. I would love to try an ASA or TA2 car at some point. I know I would love it!!
triple_s1x (08-24-2017)
