Swapping FRC trunk for hatch?
Since the car is being buttoned together soon. I was wondering if there was any reason to keep my C5Z configuration. Instead of swapping to the more aerodynamically efficient hatchback rear? I'm already running lexan in the rear, so I think the weight difference would be minimal.
Anyone reason NOT to do it?
Thanks!
Jeremy
Thanks!
Jeremy
I looked into this when I had to repair rear end damage. Only negatives I can think of are time, effort, and money. The coupe uses a different rear tub from the C5Z. The tubs are bonded to the frame, so it's a bit more work to rip it out, chip off the old urethane, and align the new tub on install. I believe the coupe also uses different rear fenders.
